Old 05-23-2011, 08:48 AM   #1
Wildwood1's Avatar
converter tripping
we just got back from our first camping trip of the season and had a wonderful time this long weekend! one problem we encountered was the breaker that runs the converter would sometimes trip. i first noticed this when the lights were getting dull. i would reset it and it would be ok for awhile but then trip again. it probably tripped 3 times on our 2 day trip. if something on the 12 volt side was overloading wouldnt the fuse blow before it tripped the breaker?? i havent had time to investigate anything since we've been home -thought i would start here first. ideas? similar problem?
Kevin and Joanne
06 wildwood 27le fbss
08 dodge ram 4x4 5.7 quad cab
07 kawasaki brute force 650i
Wildwood1 is offline   Reply With Quote
Old 05-23-2011, 08:59 AM   #2
check your battery first. Any sort of over load can cause the primary side breaker to trip.
Old 05-24-2011, 07:54 AM   #3
Herk7769's Avatar
While researching an unrelated issue, I discovered the converter power breaker ALSO powers the entire AC outlet load in my camper (except for a GFCI protected circuit in the bathroom and the outlets in the Master bedroom).
Why they did not put it on the lower usage bath/bedroom outlets I will never know. (worried about hair dryers?)
HAM CALLSIGN - KC3FFW
