Old 01-15-2014, 03:15 PM   #21
RPAspey's Avatar
Garbonz, I wouldn't doubt there's multiple recommendations out there, I'm going by a Trojan Battery Corp. technical paper I have in front of me. I have seen in other papers/forums the C/20 rate as a maximum charge rate.
2000 Cherokee, LEDs, solar, inverter, etc. '07 Tundra 5.7L DC-LB, modded as well.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 01-15-2014, 03:31 PM   #22
Denver, CO
garbonz's Avatar
Just looked at the trojan site and saw 20% for solar chargers, that why I asked. Pretty limiting for dry camping, and would not recommend Trojans for that reason.
Just saying. My Deka 6 volts can easily take 20%.
ALSO, while we are on it is the reason AGM and Gel's may be a better choice for drycampers since they can REALLY take a high bulk charge without damage...
2017 Fuse 23T
Old 01-15-2014, 04:32 PM   #23
1A Camper's Avatar
I would not get too hung up on the current %. I think that is to size the smallest charger to get for max charge in the shortest time. If you go bigger (3 stage or better) it will be charging to a voltage. If you read the charging spec on the Trojan site. It only talks about voltage level and time. That is why when you go to a charger that is above the 20% rate. The charge time do not get shorter.
As someone else said it is best when dry camping to charge battery when they hit 50% discharge and bring back up to 80%. That is where you are going to get the most charge in the shortest time.
Steve and Adele
2017 RB-195
2005 Toyota 4runner 4x4
1A Camper is offline   Reply With Quote
Old 01-15-2014, 05:48 PM   #24
RPAspey's Avatar
I've been using the Trojan T145 for 3 seasons or so with solar only charging. Not a bit of trouble. I can't remember when I used the progressive dynamics charger last, if ever since going solar.
Anyway, that 20% is only a recommendation. You can charge at a higher rate, but cell temperature and fluid levels should be closely monitored. Not to mention the increased ventilation needed to get rid of the off gassing.
Old 01-15-2014, 05:57 PM   #25
Denver, CO
garbonz's Avatar
That's very good to know. I have a 55 amp temp compensated charger that pumps every bit of 55 amps during bulk charging into my 2-6 volt Deka's and can therefore run my honda 2000 for right about an hour a day and be fine.
I have 200 w worth of solar cell but have not wired them up. Another project on the list..
2017 Fuse 23T
Old 01-15-2014, 07:08 PM   #26
RPAspey's Avatar
Get'r done. You'll wish you did it sooner. Ain't nothing as sweet as never having to haul a genny.
converter, upgrade
