Originally Posted by slurrybowl
So Ive been cranking away helping a friend convert to solar on his 5th wheel. Its a F.R Wildwood 2000 as stated in my thread title.
We almost finished the installation last night and ran into an issue. We replaced the existing 12V battery(up front, under the tongue) with a 12 V source derived from a buck converter coming off our 24V AGM battery bank (under a 30 amp breaker) I had thought this an ok place to penetrate our 12 V in. While our 12V load center is at the opposite end of the trailer, I assumed everything was connected. We landed the 12V under the existing lugs mounted to the frame of the trailer. I scrolled the forum and realized these are actually breakers? Strange lil things but ok. I put all the 12V+ under the same terminal and didnt see any 12V back at our 12V panel. Any ideas? thanks very much.
The solar is going to run all 120V AC loads in the trailer and all 12VDC loads in the trailer. When grid tied, the Samlex EVO is able to charge the batteries and pass through AC to run the 120 loads. Hope that helps.
Thanks for the input. An important point that I failed to mention is that I did indeed initially wire the polarity up flipped. where would these fuses be?
What model Samlex Evolution do you have? I have a EVO-2212 PSW Inverter/Charger. The Samlex Evolution Series Inverter/chargers have input terminals for the Solar Charge Controller. You no longer need the OEM converter/charger.
How many watts of Solar do you have? What Solar Charge controller did you get?
I have the output from my EVO-2212 doing straight to the Main Circuit panel. I hope you ordered the remote panel as it is needed for firmware updates. I had to update mine from v.68 to v.75.
Samlex support can also help you with question on the Evolution Inverter/Charger.
Let me how it goes. I love my EVO-2212. It is like having a UPS in my Motorhome.
Expanding compartment space for 2200 Watt Inverter/Charger
