Old 04-11-2016, 07:29 AM   #51
WolfWhistle's Avatar
Thanks Hammer,
I found this site...
Car Audio Terminals
WW
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 04-11-2016, 03:27 PM   #52
Thanks for the links. Thats what I'm looking for.
opie is offline   Reply With Quote
Old 04-11-2016, 03:52 PM   #53
Looked for cable reducers and couldnt find anything to go from 2/0 to 4.
I did find this... Looks like itll do what I need done and cleanly...
Old 04-11-2016, 03:53 PM   #54
The big one is $55....
I can pick this up for $15 or so a piece...
Old 04-11-2016, 07:35 PM   #55
Picked up 2 of these and a cover for the positive bar.
Old 04-12-2016, 12:00 PM   #56
Those would work ... I'm sure that #2/0 to #4 is not a common part or you could use the battery bus that Jake's sells. It has three 3/8" and one 1/4" termination I think that's right. you could add another one for your negative so you wouldn't have to terminate so many cables to your shunt
WW
Old 04-12-2016, 02:51 PM   #57
Quick question, I have 5/16 studs on my battery post, I found some 2/0 cable on Amazon but with 3/8 ends. Is 3/8 circle leads just as good as 5/16.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 04-12-2016, 03:20 PM   #58
The 3/8 will be just a bit bigger. Yes it will work. I ended up having to go eBay for my 2/0 x 5/16 lugs.
Sent from a field
Old 04-12-2016, 04:10 PM   #59
Sent from a field
Thanks, I'll check eBay before I buy. I might can find something else I need
Old 04-12-2016, 05:59 PM   #60
S, I've only used 3/8"... They seem okay to me. Plus the Shunt and battery bus (marine 4Way too) needs 3/8". I just try to keep thing uniform, not that I have it all fingered out
WW
battery
