Old 04-07-2016, 04:30 PM   #1
Critique my battery box and plans
This is where I am right now...
My plan is to install my disconnect/transfer switch inside the box between the batteries. I am also planning on installing my shunt on the inside/backside of the box.
Couple questions.... My interconnect cables are 2/0. I have some 4awg that should be here tomorrow. Should I use the 2/0 to run my positives to the switch or can I use the 4awg? I know they need to be the same length.
Same for the negative... My plan is to run it to a common post inside the tool box and then have a single ground exiting the box and tying into the frame where the existing ground is. Can I/should I use the 2/0 or will the 4awg be sufficient? Do the negatives off the batteries to a common post need to also be the same length?
Right now I do not have a ground coming from the converter/charger to the batteries. When I open up the belly to replace the 8awg with 4awg, should I also run a ground up to the box and tie it into the common ground inside the box?
opie is offline   Reply With Quote
Old 04-07-2016, 06:56 PM   #2
The size cable depends on the load. How much current (in amps ) do you plan to take out of the batteries at once? Are you running an inverter for example? If the load is close to what comes from the factory then 4awg is plenty. That alone would be a big step up from the 8awg used by FR. I really like your set up. When I figure out how I will post pics of what I am working on for our camper a 2504S. Running 3 group 31 combination deep cycle and starting batteries with 180 rc minunites each. Not as good as those golf cart batts that you have but at $72 each from work and they fit how could I not pass them up. I am going to run 4awg cable in place of the FR supplied 8awg. Jay
Jay2504 is online now   Reply With Quote
Old 04-07-2016, 07:01 PM   #3
TT power is 30 amp so total amperage at once should never exceed that. I doubt we will ever come close to that, anyway. My desire to replace the wire from the converter to the batteries is for proper charging from the power center. Which is also getting the WFCO 8955 unit upgraded to a 60 amp boondocker.
I am not currently planning on installing an inverter.
Old 04-08-2016, 05:22 AM   #4
If those batteries are not tied down somehow, I'd insulate the cover with ridged foam. Nice looking set up. Sound X like your upgrade plans are sound!
Rbertalotto is offline   Reply With Quote
Old 04-08-2016, 06:03 AM   #5
I would worry about packing the batteries down with a large foam bat. Better to put a piece of pressure treated 2x4 on top of each battery (perhaps with double stick) to keep them in place but let them breathe.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 04-08-2016, 06:08 AM   #6
Originally Posted by opie View Post
... should I also run a ground up to the box and tie it into the common ground inside the box?
You are going to have maybe 20 feet of #4 in the run from the converter, another foot or two to the switch is not going to make any difference. #4 or 2/0 either way. Whatever you have and whatever makes you feel better. Performance wise it makes no difference.
Equal length is only necessary if you are going to charge both in parallel.
2015 335DS
Old 04-08-2016, 06:21 AM   #7
I'm not going to tie them down, per say. I'm going to take up free space with blocking. There isn't enough room above the batteries for anything and in fact, I need to do a little trimming on the brace that runs length wise on the lid. It just clears now but it's to close for comfort to the battery posts.
Sent from a field
Old 04-08-2016, 06:27 AM   #8
Thanks.
All my positive leads will be equal length inside the battery box. Do the negatives coming off each bank also need to be equal length to the common connection inside the box? I do want to maintain the ability to charge them in parallel since that will help maintain equality between the banks. My only reason for using the switch I am using is if one bank goes afoul. You're reasoning for charging both banks at once makes more sense than separating them.
Sent from a field
Old 04-08-2016, 06:52 AM   #9
TURBS's Avatar
I didn't see any mention on venting.
That many batteries in that small of area will need plenty of venting for off gassing. 🏻️
Looks good!
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "0"
2015 nights camped "34"
Old 04-08-2016, 07:25 AM   #10
f5moab's Avatar
Acid absorbent material under the battery?
f5moab is offline   Reply With Quote
battery
