11-13-2013, 04:27 PM
Crusader 295RST Factory Battery Cutoff Switch
This is basically for the RVGUY......On my PT Crusader that was built in April of 2013, when I turn off the battery cutoff switch, I've notice that the electric levelers are still powered up. So without going to a lot of circuit tracing trouble, can you tell me what other electric systems are still powered when the battery cutoff switch is the "OFF" position? I would like to believe that when switched to "OFF" a factory battery cutoff switch would kill the power to everything. Does killing the power to the electronic leveling system make it loose it's programed "level"?
Thanks for any help!
11-13-2013, 04:40 PM
IMO, they do that because those levelers draw a lot of power and it's not reasonable to make long runs of the heavy gauge wire that would have to go from the battery back to that cutoff switch and then back forward to the levelers system.
The "requirement" for a cut-off switch is that it disconnect anything that would be a parasitic drain on the battery. I'm quite sure that yours performs that function well.
11-13-2013, 05:46 PM
Quite often slides are "separate" powered.
11-13-2013, 06:21 PM
gonecampin
Not to sound real stupid or anything like that, but where is a cutoff on a 295RST? We have one but I've never found a cutoff switch. BTW it too is a 2013
Randy & Jeanette Feller
2013 PT Crusader 295 RST TE C
2012 GMC 2500 Denali Duramax
Kalispell, MT
11-13-2013, 06:36 PM
In the bay with all the water and tv/sat, look to the top right and you'll see a chrome push/pull switch. "In" = Batt Disconnect.
11-13-2013, 06:41 PM
Always Learning
Not a PTM and not RV Guy, but bclemens has said that the Sunseekers are similar. The awning still technically has power, but doesn't draw anything unless you're actually extending/retracting it, so it bypasses the battery disconnect.
It doesn't answer the actual question of what all still has power that the OP asked, though.
11-13-2013, 08:03 PM
gonecampin
Thanks, I've never seen any switch there but will check it out when I get it back from the dealer.
Kalispell, MT
11-24-2013, 06:47 PM
To the op the 2 big slides have power but not the small bed slide.
2014 295rst TE Champagne
09 GMC 2500HD D/A
