Old 12-31-2010, 05:21 PM   #1
dashonthedash's Avatar
Current Draw
Does anyone know what the total current draw would be for a 32-inch LCD TV, a microwave (standard Georgetown VE model) and a single 15,000 BTU A/C? How much more current does a 15K A/C draw than a 13.5K model (had one of those in my old unit)?
Better add a 2-door fridge to that calculation.
Gary Shapiro, 2011 Georgetown 29' Class A
Dash, Molly & Lily - now at the Bridge and forever in my heart
Shadow - 4-year-old Greyhound
Hannah - 1 1/2-year-old GSD rescue
dashonthedash is offline   Reply With Quote
Old 12-31-2010, 06:01 PM   #2
Send a message via Skype™ to scubieman
Do you mean how many watts?
I'm guessing here. Alot ?
32 inch is about 400 - 500 watts
microwave should say on front but usually 700 watts or more
AC unit is about 1500 watts
Just guessing here. Really it varies alot. Each item should say on it. The older it is usually the more it draws.
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
scubieman is offline   Reply With Quote
Old 12-31-2010, 06:48 PM   #3
No, I mean current (amps). I'm trying to determine if I'm going to have to watch my usage to keep under 30 amps. I never had any difficulty with my Winnebago, but not sure how the new Georgetown will compare (don't have it yet).
Old 12-31-2010, 06:52 PM   #4
If you have 1 AC you should be fine. Two then you would have to watch. The way I see it, if you overload the 30 amp breaker it will just pop the breaker. You reset breaker and don't use that much next time.
Overall I would say you should be fine.
Old 12-31-2010, 08:01 PM   #5
ac about 12-14 running. Micro 10-12 running. Incidentals can be anywhere fron 4 to 10.
Old 01-01-2011, 01:35 AM   #6
LPG detector draws .2 amps
Single dual bulb light (198 bulbs) 2.3 amps
Single dual bulb light (LED panels) .1 amps
Light fixture over dining table (4 198 bulbs) 4.5 amps
Single reading light over bed (1 198 bulb) .8 amps
Recessed Halogen lighting, living room (6 lights) 8.4 amps Full on
2.1 amps Fully dimmed
Recessed Halogen lighting, over sink (1 light) 1.4 amps Full on
.4 amps Fully dimmed
Recessed Halogen lighting, over couch (3 lights) 4 amps Full on
1.2 amps Fully Dimmed
Refrigerator 1.2 amps
Furnace
(Suburban SF35) 7 amps
Water Pump (Shurflo Smart Sensor 5.7) 11.9 amps running, 12.6 max
Exterior porch lights (3 incandescent bulbs) 2.8 amps
Exterior Porch Lights (3 LED bulbs) .8 amps
Old 01-13-2011, 07:21 PM   #7
Hipshot's Avatar
My TT has 30 amp service. Last summer the tv (26 inch LCD) was on, the AC (15000) was on, I was taking a shower (electric water heater) was on, and wife decided to microwave a ear of corn. Main breaker in the TT tripped. I had heard of this happening. We now keep in mind what we are running.
2010 Rockwood 2604SS
2008 Silverado 1500 LTZ 4X4
Great Wife and Idiot Yorkie
True Friends are like diamonds, precious and rare.
False ones like autumn leaves found everywhere
Hipshot is offline   Reply With Quote
Old 01-15-2011, 08:32 PM   #8
I want to make sure I understand something here.
How do you figure out how many amps my furnace using? My chart is about 7 amps. Does this mean it uses 7 amps in 1 hour?
Old 01-15-2011, 09:25 PM   #9
No, what that means is that the furnace draws 7 amps of current when it is running. Current is the measure of the rate of flow of an electrical charge through a circuit. One ampere of current means that one coulomb of charge is flowing through the circuit every second. If the furnace is running for one second, it will be drawing 7 amps during that second. If the furnace is running for one hour, maybe you better get it fixed, but it is still drawing 7 amps while it is running. The current that the furnace draws is actually a measure of how well the furnace "allows" (or conversely, "resists") the flow of charge. According to Ohm's Law, current = voltage/resistance, so if you get a short circuit, there is theoretically infinite current (but not really, since there is always resistance in the wires). Excessive current can cause wiring and electrical components that are not designed for that level of current to fail, and even lead to a fire, which is why there are fuses and circuit breakers.
By the way, current can be measured by an instrument called an ammeter, which is placed in series with the circuit being measured. The instrument measures current by measuring the voltage drop across a fixed resistance.
Old 01-15-2011, 09:28 PM   #10
I guess to make it easier. If my furnance draws 7 amps how long would a 225 AH battery last?
