Old 05-05-2013, 05:57 PM   #11
Toad Haul's Avatar
I'm trying to remember here, but don't have my TT available...does the camper cable have the L-shaped prong? I was thinking all three prongs were flat....
Darren, Donna & The Wieners
Toad Haul is offline   Reply With Quote
Old 05-05-2013, 06:02 PM   #12
AquaMan's Avatar
Originally Posted by herk7769 View Post
This is what you should do. If you have two "camper" cables, and want to connect them together you are going to have to cut the 30 amp male plug off one of the cords and put this male plug on.
Marinco 305BP 30A Male Locking Plug - Marinco 305BP - 30 Amp Plugs & Outlets - Shorepower Plugs & Outlets - Electrical - Boatersland Marine
Then you can connect that cord to the camper and plug the lock ring female socket into this plug.
This is what Turbs had done. What I suggested would cost half as much and give you an adapter to use a regular extension cord while parked at home.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 05-05-2013, 06:06 PM   #13
TURBS's Avatar
Your camper should have a 1/4 turn twist lock on it.
In my first two pictures its the bigger yellow end with the nut on it.
Old 05-05-2013, 06:11 PM   #14
AquaMan's Avatar
And the male end is a round ground with 2 straight prongs.
Old 05-05-2013, 06:21 PM   #15
TURBS's Avatar
Yes ....
Which would allow the cord I linked to at amazon to connect the two.
Original cord with camper plugs into camper.
New cord connects to that and then the pole.
Least inexpensive way to do this.
Old 05-05-2013, 06:30 PM   #16
Toad Haul's Avatar
okay...think I'm getting it now.... I just didn't think the outlet at the hitching post had an L-shaped prong on them.... I'll see if I can't find the connector at Lowe's maybe.... if not, I can order online or even buy an extension cord to just have one handy.
Thanks everyone for helping out!
Old 05-05-2013, 06:39 PM   #17
Engineer of Crazy Train
ChooChooMan74's Avatar
Extensions are cheap on Amazon.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 05-05-2013, 06:41 PM   #18
Herk7769's Avatar
Yes ....
He has two cords already; just two identical camper cords. they won't connect to each other without an end change on one or an adapter special made to have a 30 amp female and a camper end male.
The cord is the expensive part. Might be just as easy to cut off the camper end (female) and put a 30 amp female on it to make an extension cord.
Power Zone ORVCONN RV Cord Replacement Connector 30A , Female
HAM CALLSIGN - KC3FFW
Old 05-05-2013, 06:46 PM   #19
TURBS's Avatar
Yep so all he needs is a male and female 30 amp twist lock.
Missed the two cord part.
Old 05-05-2013, 07:10 PM   #20
AquaMan's Avatar
Now you're catching on.. . Then use the extra camper end to make an adapter by adding a male 15amp plug. Essentially a $30 adapter for next to nothing.
