Old 06-08-2011, 02:27 PM   #11
Originally Posted by herk7769 View Post
There should be a troubleshooting guide in your converter manual.
I would start there and a call to the Tech Support line for your converter.
I think I will.
Thanks,
Al
ALMcKinney is offline   Reply With Quote
Old 06-08-2011, 02:30 PM   #12
Originally Posted by jimh View Post
what voltage do u show on the battery with all (shore power) disconnected. what voltage do u show on the bat with shore power on?
my old standby response is to check and see if the battery is bad.
Quick question what would happen if the battery neg was disconnected with shore power hooked up? Would it have any ill effects on any 12 Vdc circuits?
I thought I read not to do that somewhere on the forum i.e. someone did and they fried thier stereo or something that was 12 Vdc.
Al
Old 06-08-2011, 03:25 PM   #13
Herk7769's Avatar
I thought I read not to do that somewhere on the forum i.e. someone did and they fried their stereo or something that was 12 Vdc.
Al
Al, the battery is the primary 12VDC source when the converter is powered or not. The converter, if powered, will kick in when the battery voltage starts to drop due to load (like opening a slide). It will shut off after the battery is recharged.
The converter is capable of providing 55 amps at 12 VDC total at peak production. If the battery is completely disconnected the converter will "read" zero volts from the battery and stay on constantly providing DC power to all items requiring DC.
HAM CALLSIGN - KC3FFW
Old 06-08-2011, 03:36 PM   #14
Sir (I noticed the rank),
Thanks,
But if the converter's output voltage was not regulated it could damage a 12 volt circuit then if the battery was removed from the circuit.
Sorry for all the questions trying to educate myself.
Kind regards,
Al (US ARMY Veteran)
Old 06-08-2011, 03:53 PM   #15
Herk7769's Avatar
Thanks,
Kind regards,
Sorry Al, but I am a PFC now.
I see what you are getting at. If the converter is "running away" then the battery would act like a shock absorber and that would certainly boil it dry. Get on the horn to Tech Support ASAP.
Old 06-08-2011, 05:10 PM   #16
jimh's Avatar
if the converter is working properly, i wouldn't think that disconnecting the bat would damage anything. the older trailers useto power the trailer without the bat. my understanding is that the bat is always in now. my trailer has a disconnect switch that separates the converter from the bat. with it off, the bat is out of the system but the rest of the trailer will still be powered by the converter.
the reason i ask abt the voltage on the bat with the shore power off for a few minutes was to determine if u had a bad cell. you should read 12.6 but i wouldn't quibble abt a couple tenths of a volt.
the next question was going to be if the lights in the trailer work with the shore power disconnected. if the bat voltage remained good and the lights would not burn, i was going to suggest looking for a battery disconnect that may have the DC shut off to the trailer.
even if the converter has problems, with a good bat, and the shore power disconnected, u should still have lights and the frig should work on propane.
on my trailer, the bat disconnect separates the battery from the converter. (everything from the DC fuse panel will still get power from the converter). the slide outs hydrolics and the vehicle remain connected to the bat.
i'd really like to know what the battery voltage is when the shore power is on. if it is approaching 14.5 or 15 volts, i would really be concerned.
jimh is offline   Reply With Quote
Old 06-08-2011, 06:08 PM   #17
jimh's Avatar
One other question. How long does it take to boil the water out? A day, a month?
Old 06-08-2011, 08:37 PM   #18
The rate mine was boiling I would say less than 24 hours in overcharge. Average use I would say check them every 90 days and add distilled water if needed,
Al
Old 06-08-2011, 11:38 PM   #19
jimh's Avatar
that's too much. i was hoping it wasn't that serious.
it may be nice to play with it but that sounds like the manufacture would be ur best bet.
the only other thing i would suggest would be to double check ur wiring. make sure they didn't change the wiring locations from the original and the replacement. not very clear (to me)...watch the labels.
Old 06-10-2011, 08:37 PM   #20
Ok put a new converter in and it seems to be working no boiling battery.
I checked the voltage and I have 13.4 volts going to the battery and I also have the same amount across my 12 Vdc circuits is this normal?
Al
