Old 06-10-2011, 08:49 PM   #21
oldprof1's Avatar
12.23 volts indicates an almost dead battery. Charging voltage is typically 13.8 V. After charging a battery let it stand for 24 hours then test the voltage, It should be 12.8 to 13.2V.
oldprof1 is offline   Reply With Quote
Old 06-10-2011, 10:55 PM   #22
jimh's Avatar
that sounds normal to me. by tomorrow, u should be able to read ~12.6 on the battery without shore power hooked up. i wouldn't worry if u were a couple tenths, either way, off that mark.
was the one giving the problem a new one also? (i'm too lazy to go back and reread the post).
jimh is offline   Reply With Quote
Old 06-10-2011, 11:01 PM   #23
jimh's Avatar
Originally Posted by ALMcKinney View Post
Isn't the regulator part of the converter?
Al
it is. i believe he is telling u what part to repair. probably isn't a hard fix for someone with basic power supply knowledge. it could be an adjustment.
Old 06-10-2011, 11:05 PM   #24
Yes, I bought a replacement 7155 unit and it was putting out almost 15Vdc and wouldn't shut down and boiling my battery.
ALMcKinney is offline   Reply With Quote
Old 06-10-2011, 11:35 PM   #25
jimh's Avatar
well, that would be one for them to play with.
glad u got it working.
my last trailer (an 84 fleetwing...only one i ever saw) would not charge the battery. i looked inside the converter and there was a wire disconnected to the charging circuit. i reconnected it and it would boil the water out in abt a month. found an adjustment inside that i played with and managed to get it to work almost right (would go abt 2 mos or not charge at all). the old converter also switched off battery when u plugged into AC. (the charging circuit would stay connected though). the new ones are on line all the time. i haven't had reason to go into one of them yet.
Old 06-10-2011, 11:46 PM   #26
I replaced it with the PD4600 from Best Converters, This one works like a charm and has the charging wizard on it. Randy at BC was a great help.
Al
