Old 11-12-2019, 02:40 PM   #1
Dead 110 outlets
I have a 2002 Sierra T21 that is having electric issues. Replaced 15 Amp breaker and 2 plugs with no change. I have not located a GFCI OR GFI in the trailer. Could it be an inverter fuse ?
Would like to find wiring diagram but as Forest River
Keeps no records I am guessing.
I have searched forum for answers and not really find finding what I need.
Wish4sun is offline   Reply With Quote
Old 11-12-2019, 02:46 PM   #2
50a or 30a service?
You have got to start with basics.
Have you checked the supply voltage at the power source where plugged in with a meter?
Are you using an adapter?
Have you checked the voltage at the power distribution box with a meter?
Have you checked all the outgoing feed voltages at each breaker?
Days Camped: '16=46 '17=30 '18=51 '19=53
Old 11-12-2019, 02:46 PM   #3
AudiDudi's Avatar
I'd guess that the bathroom outlet is a GFCI. Either that or the Kitchen. I cannot imagine there not being a GFCI somewhere.
Mike and JoAnne
Montana Summer / Arizona Winter
2016 Prism 24G /2002 HitchHiker 38LKTG
ACME EZTowing a 2015 Chevy Sonic RS Hatchback
AudiDudi is offline   Reply With Quote
Old 11-12-2019, 05:13 PM   #4
All three of the TT's that I have owned have had a GFCI in the bathroom. I also helped a couple out at a campground with electrical problems. I showed them the GFCI in their bathroom and everything came back on line.
BarabooBob is offline   Reply With Quote
Old 11-12-2019, 05:41 PM   #5
In my experience, when all 120v outlets are dead and other AC items work (like Microwave) the GCFI that protects ALL of them is tripped.
Most common location is in the bathroom.
Keep looking, there is one somewhere.
When you find it, make sure to push the reset button firmly. Some I've found are hard to reset with my large fingers so I use the eraser end of a pencil.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 11-12-2019, 05:48 PM   #6
Flybob's Avatar
If no GFCI in bathroom or kitchen area, check an outside outlet. I have not seen an RV in a long time without at least one GFCI.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-12-2019, 06:07 PM   #7
Retired Old Fart
dward51's Avatar
And that GFCI will feed (and protect) other outlets further down the line on the same electrical run. So if the GFCI is out or tripped, you will not have power at any outlet after the GFCI.
Just the 2 of us in a...
2015 Freedom Express 246RKS
2002 GMC Sierra 1500
dward51 is offline   Reply With Quote
Old 11-13-2019, 09:12 PM   #8
Still looking and like we all think bathroom or kitchen .
It is not ! So in looking for the GFCI A THOUGHT I replaced the propane/electric water heater with a 6 gal propane only now Iím thinking about looking at that since itís water it could be GFCI. Right?
Anyone ever see one there?
As I said before an owners manual or wiring diagram
Would be nice. If I ever find one Iíll post it with a link o the pdf to download so others can see it.
Old 11-13-2019, 09:29 PM   #9
Is it all outlets or just some of the outlets?
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
mwdilday is offline   Reply With Quote
Old 11-14-2019, 08:06 AM   #10
My rig does not have GFCI outlets only GFCI breakers. Also your inverter will have a reset button usually hidden.
DYNAMAX 2016 FORCE HD
houstonstroker is offline   Reply With Quote
Old 11-14-2019, 08:24 AM   #11
Head Rambler
We had an RV once where the only gfci was the receptacle on the outside under the awning. All the rest of the receptacles were daisy chained to that one.
I also remember that the gfci in one RV was the one for the fridge.
Gotta go campin!
Old 11-14-2019, 01:01 PM   #12
What he said.....
Old 11-14-2019, 11:08 PM   #13
Yes I am still looking fridge I havenít done and outside under awning everything work except plugs in bathroom, kitchen and tv jack. Oh and havenít checked the inverter.
Old 11-14-2019, 11:53 PM   #14
As houstonstoker suggested, have you checked your breakers for a GFCI breaker?
In fact, have you checked all your breakers? It's not always easy to see when one trips. Turn them off, then back on.
2011 Traverse LT, 3.6L, FWD
Old 11-16-2019, 05:25 PM   #15
Witch Doctor's Avatar
In my old Rockwood mine was located in the outlet in the storage locker, it could be anywhere, but you do have one, never seen a unit without one.
Coachmen M/H
Concord
2018 / 300 DSC
