Old 05-14-2012, 06:41 AM   #11
Herk7769's Avatar
With the 4, 6, or 7 pin trailer wiring systems the ground for the lights is the frame and the white ground wire in the connector.
The "common ground" connection on the plug is only hard wired to the battery charging line, breakaway switch and the trailer brakes and then bonded to the trailer frame.
The running, turn and stop light grounds are through the frame.
However, that wire connection between the frame and the the ground pin on your connector is your weak link. If that connection is corroded you won't get a return path for the lights without being hitched.
See attached wiring diagrams.
ID:	13746   Click image for larger version
ID:	13748   Click image for larger version
brakes, led pad, battery
