Old 05-10-2012, 12:45 PM   #1
Fishfireguy's Avatar
Dead Batteries- No Lights or Brakes when hooked up to truck
So I went to check on our Surveyor SP-186 which is in storage. Even though I had disconnected the batteries, they are both dead. So, I hooked up to my truck and found that none of the running or brake lights or the trailer brake would would work. Would the batteries on the trailer be the cause of this?
Any help would be appreciated!
Fishfireguy is offline   Reply With Quote
Old 05-10-2012, 01:26 PM   #2
Herk7769's Avatar
Sounds like it could be a corroded plug. You can try cleaning the contacts with a Bargman plug brush.
Each line is fused seperately and while it is possible your dead batteries froze and shorted themselves out, that should not have an impact on the running lights.
HAM CALLSIGN - KC3FFW
Old 05-10-2012, 10:46 PM   #3
Dead batteries on the camper have no effect on the camper lights. Illegal to tow without the batteries, as they operate the beak away switch, but who knows whether they are connected or not.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 05-13-2012, 06:08 PM   #4
Thanks for the advice folks! As it turned out, once the trailer was hooked to the hitch, everything worked just fine! Although I do believe my batteries are shot.
Old 05-13-2012, 07:06 PM   #5
Herk7769's Avatar
Doh! You needed a ground (through the hitch ball) to complete the circuits!
Old 05-13-2012, 08:22 PM   #6
Triguy's Avatar
That ...
I did not know.
I learn something new here everyday.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 05-13-2012, 09:47 PM   #7
Herk7769's Avatar
What threw us was your subject line.
"Dead Batteries - No Lights or Brakes when hooked up to truck"
I made the assumption you were actually "hooked up to the truck" not just plugged INTO the truck while unhitched. Whoda Thunk?
Old 05-13-2012, 09:55 PM   #8
Jack of All Trades
RJHuser's Avatar
But shouldn't the ground through the 7-pin connector taken care of the ground path? I know that on my TT my running and stop lights and power work without the truck physically connected to the TT through the ball.
Sounds like there is still a wiring problem in the umbilical.
Rick & Debbie; Brandy & Schnoodle (Dexter & Fritz R.I.P.) the Doxie "Kids"
2015 Jayco Pinnacle 36RSQS 5'er
2018 GMC Sierra Denali 3500HD, 6.6L Diesel Dually; B&W Companion 5'er hitch
ScanGauge, TST 507 TPMS
RJHuser is offline   Reply With Quote
Old 05-13-2012, 10:02 PM   #9
Herk7769's Avatar
Maybe, but I have seen many boat trailer light issues fixed by cleaning the rust off the ball. I think your bad ground in the socket may have merit. The juice has to get back to the truck somehow.
Old 05-13-2012, 10:02 PM   #10
There is a ground pin in the 7 pin plug. Pin #1 on Lou's diagram. Sounds like it is broken in either the truck or the camper. Should not rely on the ball hitch for a ground. Usually too much rust and stuff on the slide portion of the hitch for a "good" ground.
LadyWindrider
brakes, led pad, battery
