09-17-2018, 06:29 PM
#21
Originally Posted by MR.M
either way not worth arguing about.
I agree totally.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
09-17-2018, 06:49 PM
#22
Unless I missed it, I did not see anything about what you are running on battery (12V). If you have are 3 way fridge is it running on 12V? As for the battery charging during towing, unless you have made some major mods to the TV wiring, the amount of charge you get during towing is just above what is needed to cover the parasitic draws so no real charging. Before you replace items or add items, you need to determine what your current draw is.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
09-17-2018, 07:51 PM
#23
I think Mr.M needs a new voltmeter that is a little more accurate.
2007 Surveyor SV230 - 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
09-17-2018, 08:49 PM
#24
Thanks Flybob. Basically the only thing running on the battery overnight was the refrigerator running on gas. Just got back from having the battery load tested. It dropped a cell so I purchased a new one.
09-18-2018, 09:13 AM
#25
My meter matches what my charger says. meter is fine as is charger .
09-18-2018, 04:13 PM
#26
Originally Posted by CedarCreekWoody
Hmmm, you might want to re-verify your source for that info.
source verified ! twice now in the last 2 days source voltage meter and charger . battery today was 60% 12.58 volts . fully charged 13.2 to 13.5 . maybe you should pick up a meter and go do some checks and not rely on some charts
09-18-2018, 05:03 PM
#27
There is something really wrong with your readings.
60% charge should be 12.24v not 12.58v which is a bit over 80%
A fully charged battery (100%) will be 12.73v after the surface charge has dissipated. You will get a reading of 13.5v only while the surface charge is still there.
09-18-2018, 05:14 PM
#28
Whatever works for you...
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
09-18-2018, 05:24 PM
#29
Originally Posted by farmers04
Been RV'ing for a couple of years, but have been renting to get an idea of what would fit our needs. We finally purchased a Rockwood Mini Lite 2109S last year. We have taken it out multiple times and really enjoy it, but the battery is becoming a huge problem. We just got back from a trip and by the time we reached our stop for the night (Walmart) the battery was completely dead. The next morning we went to our destination and I plugged the trailer into my generator. The indicator light on the panel showed fully charged when we went to sleep that night, but it was dead the next morning again. I'm assuming that the battery is toast, but I had some questions I was hoping someone could answer. First, shouldn't the battery be charging when hooked up to my truck when towing? Second, I have a Battery Tender trickle charger, will that work for charging at home or should I get something else. Thanks for you help
Your truck should charge the battery unless it is like mine I had to put in a relay under the hood for the truck to charge my battery used to come with the vehicle when new and they kept it in the glove box or behind the seat. Newer trucks I'm not so sure tho. Since I keep my trailer at home it is always plugged in and has always been fine.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
11-10-2018, 08:11 AM
#30
I used battery tender, before not much luck, over charged ruined batteries. Now I keep small solar charger on all the time keeps batteries good all the time. Also keep one on my zt lawn mower when not in use, the last battery I had to buy for it going on 6 years now. Vary happy
11-10-2018, 08:14 AM
#31
I have never over charged a battery on a Battery Tender. I have been u s ing them since they came out. You have something else wrong or not A battery tender brand!
11-10-2018, 08:26 AM
#32
What he said! You won't over charge on a battery tender brand charger!
Once upon a time- I bought a knock off battery charger from Harbor Freight. It looked like a battery tender but was cheaper. It cooked the battery in my motorcycle over one winter. Now I use only battery tender Jr on my truck, RV, lawn mower and motorcycle. No problems since.
Peace!
Dan & Rita D
11-10-2018, 08:28 AM
#33
X2!
11-10-2018, 06:43 PM
#34
Well the one I had was a battery tender brand just didn't work for me thanks
11-10-2018, 07:27 PM
#35
If you are in an area that has frequent severe thunder storms, I recommend checking battery maintainers after bad storms. I have several Battery Tender (TM) and several CYTEK maintainers. I have had one damaged by a power surge during a storm and the device stopped managing the charge rate and damaged the battery. This was not a device issue.
TST Tire Monitors
2 100W solar panels
