Old 11-11-2014, 08:14 AM   #1
Brushhog's Avatar
Dead battery
Hey guys, just brought home my "new to me" 2010 Sandstorm 203SLC toyhauler. This is my first camper and have no knowledge of camper stuff. It was just in for service and everything worked great according to the shop, now that it's home I tried to start up the on board generator and it sounds like the batteries are dead. My question is how I can get it started and once started will the generator recharge the batteries?
Brushhog is offline   Reply With Quote
Old 11-11-2014, 02:59 PM   #2
A couple of thoughts come to mind. CAVEAT: I have only owned boats, pop-ups, and a-frames. None of these had a separate generator, so my knowledge of how things work on your camper is generic only.
1. Why didn't the tow vehicle charge the battery on the way home? Was the battery disconnected while work was being done, and never reconnected? Is the battery cut-off switch in the correct position?
2. To get the generator started, recharge the batteries using a battery charger, or use jumper cables.
3. If things are working correctly (switches could be left in the wrong position from the work performed, and there could be failures), the generator should recharge the batteries once running.
4. If the battery(ies) were completely discharged, they might not be recoverable. A place that sells batteries can run a check for you.
You will probably want to learn how your 12V system in your camper works - at least somewhat. Learning by buying replacement batteries is an expensive way to go.
just my thoughts
Fred W
Old 11-11-2014, 04:48 PM   #3
HONDAMAN174's Avatar
I always take my 900amp jump box with me when I travel. Never fails that another camper needs a jump from someone leaving a door open or light on.
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
Old 11-14-2014, 09:42 AM   #4
Brushhog's Avatar
Thanks guys, I got it started. I put a charger on one of the batteries and left it over night and got it fired up the next morning.
Do you guys recommend a solar charger or having my electrician buddy install an outlet to plug into while it sits unused in the driveway? And if I install a shore power outlet what size should it be?
Old 11-14-2014, 10:04 AM   #5
camaraderie's Avatar
If all you are doing is looking to charge the batteries...suggest you just get a trickle charger like this one and use an outdoor extension cord to charge it up from the house power. Useful for your car batteries, cycles etc. as well.
I would be concerned about the condition of your batteries given that they were flat and are probably 4 years old. Suggest you take them down to the auto store and get them load tested before you go camping and get surprised. Link to a home load tester below as well.
Amazon.com: Deltran Battery Tender (021-0128) 1.25 Amp Battery Charger: Automotive
6 Volt/12 Volt Battery Load Tester
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 11-14-2014, 10:09 AM   #6
Flybob's Avatar
I recommend a "Battery Tender" Will not over charge and can be run on a simple extension cord. I use these on every battery equipped thing I own that has occasional use. I have had a 7 yr old motorcycle battery that was always on a battery tender start a large bike. Do not get a trickle charger. search for Battery Tender brand.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-14-2014, 11:00 AM   #7
rracer5's Avatar
Didn't see where you mentioned how long you had it home before you tried to start the genie.
If it was more that a week, then the natural parasitic draws (CO alarm & others that are hard wired) will drain the battery(s). Keeping it plugged into the house will keep the battery(s) charged and ready for your next trip. Or, disconnect the battery(s) or install a battery disconnect.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 11-14-2014, 11:19 AM   #8
Brushhog's Avatar
Racer I had it home for a couple days but it sat at the shop after it was worked on for about a week, it has a disconnect switch that I turn off now. Thanks for the info guys!
2012 Toyota Tundra Crew Max TRD Off Road
Old 11-14-2014, 11:31 AM   #9
rracer5's Avatar
2014 Sanibel 3250
battery
