Old 01-24-2015, 12:20 PM   #11
Ford Idaho's Avatar
Something like this under the jack will keep you from over extending.
Old 01-24-2015, 12:37 PM   #12
Eaglelover's Avatar
Send a message via Skype™ to Eaglelover
Jack Problem
The jack shown in the previous photo is imported by LCI and in the drive train there is a small gear about 1 inch in diameter. The gear is cast and broke in half when I was hooking up. There is NO replacement available. The jack is imported by LCI and the only parts available are lights and switches. After several calls to LCI, I finally got the service manager and he said as a help for good customer relations he would send me a complete jack at no charge and he DID. Waa Hoo for LCI. Frank
Eaglelover is offline   Reply With Quote
Old 01-24-2015, 03:51 PM   #13
Ricochet's Avatar
It was my own foolishness which caused the overextension of the jack. I was trying to get a better angle on the door to unload our trike.
Rick
2015 Work and Play 30WRS
2011 Ram 2500 I-6
Ricochet is offline   Reply With Quote
Old 01-24-2015, 05:25 PM   #14
Ford Idaho's Avatar
I understand completely....
Blocking under the jack for a higher lift and/or a board or two under the end of the tailgate.....
Old 01-24-2015, 05:48 PM   #15
I know exactly what you are trying to do in relationship to the (Ramp Angle)! My BIL has a Harley Trike and the Ex pipes (Large) under the Trike , (Rub) unless he (Jacks up) the front of his (F/R All American Toy Hauler)! Youroo!!
Old 01-24-2015, 07:57 PM   #16
Ricochet's Avatar
...that and a good dose of knowing "how high is high enough"
Rick
2011 Ram 2500 I-6
Old 01-25-2015, 07:15 AM   #17
DKRITTER's Avatar
You might think of changing the angle of the ramp itself. You can get light weight ramps that you can add and lessen the ramp angle. Kinda spendy.
DKRITTER is offline   Reply With Quote
Old 01-25-2015, 07:21 AM   #18
Ricochet's Avatar
I think that's the right idea! I was thinking of getting 3 2"x8" and laying them out as ramps. Same basic principle, but less $$$!
Rick
2011 Ram 2500 I-6
Old 01-25-2015, 07:49 AM   #19
To prevent this problem this is what I do with the last two campers I have had. I run the jack out all the way and stop at the first chatter or sound. Then back off slightly and paint a red stripe on it. Then do the same thing for the retraction. After that it is easy to extend and retract without hitting the limit. Hope this makes sense.
comfun1 is offline   Reply With Quote
Old 01-25-2015, 10:08 AM   #20
Ricochet's Avatar
That's a great idea! Thank you!
Rick
2011 Ram 2500 I-6
electric
