Old 01-24-2015, 06:37 AM   #1
Ricochet's Avatar
Dead Electric Tongue Jack
Our new Work and Play 30WRS came equipped with a Ram 3500 electric jack. I raised the front of the trailer, while hitched to the TV, to minimize the angle of the door ramp for clearance while unloading the trike from the rear. I fully extended the jack. After unloading, I tried to lower the tongue, but the jack motor would not engage. I checked all the connections, the fuse panel, and the reset button, and all appeared OK. I ended up lowering the jack manually. Is this jack toast, or can it be repaired?
Rick
2015 Work and Play 30WRS
2011 Ram 2500 I-6
Ricochet is offline   Reply With Quote
Old 01-24-2015, 06:55 AM   #2
KyDan's Avatar
I have no experience with this jack but if I were you-- I'd get a meter or test light
and make sure there is power going to the jack. Test as close to the jack as possible.
In other words find the wire that feeds the jack out on the tongue area and make
sure it has 12v actually getting to the jack.
I'm guessing you blew a fuse somewhere when you hit the stop at full up.
Peace!
Dan & Rita D
Blue Ox WD hitch
KyDan is online now   Reply With Quote
Old 01-24-2015, 07:14 AM   #3
caper's Avatar
My jack has a inline fuse could this be the problem?
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 01-24-2015, 08:49 AM   #4
fonzie's Avatar
Usually there is an in-line fuse as per picture.....black fuse holder in red wire.
Fonzie
Old 01-24-2015, 09:31 AM   #5
KenHwy61's Avatar
I had my fuse blow twice for no apparent reason. Some had suggested water was getting inside the motor. I ordered a vinyl jack cover and a resettable 12v 40 amp circuit breaker from amazon.
Seasonally in the Grand Marias, MN campground
On the beautiful shores of Lake Superior
Aviator Wright-Flyer#1908
2012 Ram 2500HD CTD
KenHwy61 is offline   Reply With Quote
Old 01-24-2015, 11:50 AM   #6
Grandpa's big Blue truck
russellsawatsky 56's Avatar
Probably the in line fuse have had to replace ours a couple of times .It was hard to find the first time. Our jack broke last trip last summer, we have to rebuild or replace it this spring main drive gear on motor
2016 Ford F150 screw Ecoboost max tow 6.5 bed
2016 Ford Edge
2012 Freedom Express 310 BHDS
Love camping with grandkids
russellsawatsky 56 is offline   Reply With Quote
Old 01-24-2015, 11:50 AM   #7
Ricochet's Avatar
Thank you all for your responses. I traced the wiring back and found a circuit breaker, which had been tripped. Reset, and problem solved!
Rick
2011 Ram 2500 I-6
Old 01-24-2015, 12:12 PM   #8
BooBoo23's Avatar
Don't extend or retract the jack to the limits as that may overload the motor and cause a fuse or circuit breaker to trip. There are no limit switches on nearly all the tongue jacks.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
BooBoo23 is offline   Reply With Quote
Old 01-24-2015, 12:16 PM   #9
Rivnut
Rivnut's Avatar
It was explained to me that when the jack reaches it limits, it makes a chatter, then blows the circuit breaker. So It was suggested to buy an in line RESETABLE circuit breaker, mount near the jack. cost a dollar or two. Tired of replacing fuses
Rivnut is offline   Reply With Quote
Old 01-24-2015, 12:18 PM   #10
Mr. Dan's Avatar
Thanks for replying with the answer to your problem!
Some electric motors blow fuses when they hit their hard-stop point. I had the condition with the front jacks on my 5th wheel until people here told me to get an automatic resetting breaker to stick in the fuse holder. Have had no problems since.
See this:
Originally Posted by fonzie View Post
When the motor stalls, the current goes way up and will burn the fuse......called "LRA"
What is locked rotor current
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
electric
