Old 07-19-2015, 06:46 PM   #11
Ford Idaho's Avatar
Originally Posted by oldtool2 View Post
And I hope it always does. Looked at it but wanted something portable.
Jim
Ummm, it is portable.
One end plugs into the power outlet trailer plugs into the other end.
I chain it down so it is less likely to walk off.
Old 07-19-2015, 06:53 PM   #12
We installed the Progressive Industries EMS-LCHW30 in our popup after a surge in a CG damaged our converter. In the years following the install it cut power twice while connected (low voltage) and indicated improperly wired power posts a couple of other times. We traveled 4-6 weeks each year for 5 years so the unit saw dozens if not hundreds of different connections. When we bought our Vibe last year a EMS-HW30C was the first purchase I made. They are easy to install, customer support is very good, the design is modular and others have shared that PI will help you troubleshoot a unit and sell you components as needed.
The readout, while not intended as a precision monitoring system, is wonderful. It displays voltage, amperage (which is very useful in monitoring the various systems in the camper), and frequency. The unit also delays reconnecting after a fault to prevent damage to air conditioners. I have no association with PI, purchased the first based on recommendations found on numerous forums and the units have not disappointed.
pjnlorrie is offline   Reply With Quote
Old 07-19-2015, 07:26 PM   #13
Phat Phrog Stunt Crew
elind's Avatar
oldtool2, The Progressive Industries PT30C 30 Amp would be a good choice because it's a lifetime warranty that's made in the USA. Another good choice is the TRC 30 Amp Surge Guard Md. 34830. The TRC has a limited warranty but is cheaper and does the about the same job.
Both models protect you against too high and low voltages, bad pedestal wiring, and restarts in 2 min 15 seconds after the problem corrects itself.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 07-19-2015, 08:48 PM   #14
The Progressive Industries PT30C 30 Amp would be a good choice because it's a lifetime warranty that's made in the USA. This was the deciding factors for me. It will be nice to have something made here for a change.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 07-20-2015, 05:23 PM   #15
I'll pile on. I bought a new used 2015 Viking 17FQ and the dealer said a Surge Protector should be the number one upgrade you should get. We went one trip without one, and I was nervous. So Thursday I bought the EMS-HW30C from Amazon and installed it before our weekend outing. On day one we were playing cards and click, power went out. The Progressive went through its restart and gave the code PE4 (low volts). Don't know why, it just happened. About 2 hours later a thunderstorm came through and a lightening bolt hit - click. Restart and gave the PE8 code (low line frequency).
So first time out it protected twice. Cool. Neither of those conditions would have been protected against with just a surge protector. I can see that over the life of the unit it will save at least some wear and tear on the sensitive electronics from these "other" events.
One question I had is there is no code if the unit cut the power for a power surge. Am I guessing right that it would show high voltage as the same thing?
2015 Viking 17FQ TV: 2005 Lexus GX470
bbrowncods is offline   Reply With Quote
Old 07-20-2015, 06:27 PM   #16
I did the research and the Progressive is the way to go. Save he from damage in an electrical storm. Lifetime warranty. I had loose prongs and it was replaced no problem. I got mine at Tweety's.
robbdrell is offline   Reply With Quote
Old 07-20-2015, 09:15 PM   #17
Just read all the posts here and decided to order the Progressive Industries EMS. With a brand new trailer, I don't want any problems. I've been wanting to get one of these anyway. Thanks to all of you for your posts and your info. It is greatly appreciated. Take care all, and travel safe.
olbob52 is offline   Reply With Quote
Old 07-20-2015, 09:16 PM   #18
TURBS's Avatar
Smart man!
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "15 nights"
Old 07-20-2015, 09:26 PM   #19
Turbs, would you talk to my DW ?!?!?!?
Old 07-20-2015, 09:38 PM   #20
Iwannacamp's Avatar
And mine too???
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Iwannacamp is online now   Reply With Quote
