Old 07-22-2015, 02:27 PM   #51
TURBS's Avatar
Originally Posted by HSVBamaBob View Post
Jim, I saw TURBS installation in his unit last year and I suspect most RVs would be similar: It installs near the main power panel inside the rig.
Correct, I removed distribution panel "5 minutes" and installed right behind it on the floor.
1 hr install.
It's basically under my sink non accessible to anyone.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "15 nights"
Old 07-22-2015, 03:19 PM   #52
Forester Fred's Avatar
Location: On the road between New Hampshire and Florida
I did my install today on my hardwired unit. Took me longer to figure out where I wanted to put it then it did to hook it up. The 2301 is a rear queen bed. The transfer switch is under the bed so that seemed to be the logical place to put the EMS. I was going to put the EMS after the transfer switch but decided to install it before it. I don't use the generator all that much and when I do it's only to run the A/C. We don't do any boondocking so I'm more concerned about campground electrical service problems. The generator is an onboard Onan/Cummins unit so I'm counting on it running without frying all the electronics in the coach.
Forest River left plenty of extra cable under the bed so all I had to do was cut it, strip it and attach it to the EMS. I installed the EMS where the transfer switch was originally mounted and moved the transfer switch a little forward. I mounted the readout on the front of the bed under the electrical panel. That way I won't be looking at blinking lights all night but it's easy to see from anywhere forward of the bed.
Before I buttoned everything up I plugged into shore power and made sure the system was working correctly.
While I had the bottom of the bed opened up I also fixed the uphill water tank fill problem that a lot of people were complaining about. The fill tube ran slightly uphill at one point so I pushed it down to where it's all downhill from the fill opening to the tank and zip tied it into place.
Forester Fred is offline   Reply With Quote
Old 07-22-2015, 03:21 PM   #53
TURBS's Avatar
Looks good
TURBS
2011 32bhok Sabre
Old 07-22-2015, 03:25 PM   #54
TURBS's Avatar
Mine.
ID:	83754Click image for larger version
ID:	83755Click image for larger version
TURBS
2011 32bhok Sabre
Old 07-22-2015, 03:31 PM   #55
RETIRED
n-e-d's Avatar
I like the plugs to bypass it if needed? Will have to redo mine when I get a chance
Mary and Me
2015 2650s "Finally"
2015 Jeep Cherokee
2016 Ford Race Car Red 350HD Cargo Van HR DRW EXT DIY Daytripper "My Little Red Corvette"
n-e-d is offline   Reply With Quote
Old 07-22-2015, 03:33 PM   #56
BamaBob's Avatar
Nice job Captain Skip!
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 07-22-2015, 03:36 PM   #57
BamaBob's Avatar
X2 I made a mental note about that last year. When the time comes to install our hardwired unit I will do the same!
Smart engineering Ron - in the unlikely event your EMS goes south, it's a simple process to get you rig powered up again!
IF you DARE to plug into a power outlet without your Progressive EMS!
Old 07-23-2015, 06:29 AM   #58
Seems there are plenty of secure locations to install one. As long as you have room behind your panel that would be a logical and secure location, I didn't need any more work right now so went with the simple way. I can lock it to the post so don't see it taking a walk.
Now back to installing my new alarm system, spare battery, inverter and led lighting. Got to work while the heat and humidy is down for the next few days.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 07-23-2015, 07:51 AM   #59
craigster_mi's Avatar
Originally Posted by Iwritecode View Post
Theft protection is probably the biggest advantage over a portable unit.
here's what I did with my "portable" unit. kind of a variation on turbs installation. I turned my "portable" into a "permanent" by cutting the supply wire and installing male and female plug/receptacle. this eliminates having the unit plugged into the power pedestal (and possible theft). if there is a problem with the unit I can unplug it and reconnect my power without it in line. I can also take it out and "test" sites if I want to. Also if change trailers I can take it with me.
craig
ID:	83847   Click image for larger version
2014 F150 Eco
2015 Rockwood Mini-Lite 2504S
craigster_mi is offline   Reply With Quote
Old 07-23-2015, 07:52 AM   #60
TURBS's Avatar
craig
Great idea!
TURBS
2011 32bhok Sabre
