Old 09-30-2011, 11:20 AM   #1
pattersonb's Avatar
Deep Cell Battery
My 2008 Cardinal 30RKLE 5th wheel has the original battery. Between camping trips, the trailer is stored - plugged into "shore power" - on my driveway. Presumably, the battery is being constantly supplied with a charge from the AC power source. Most of my camping involves being connected to "shore power", so my actual battery-only use is minimal. My questions are: 1) Does this shorten the life of the battery? 2) Do modern deep cell batteries have the same problem with "discharge memory" as old units did? 3) If so, should I let the battery discharge completely and then recharge it? Thanks!
pattersonb is offline   Reply With Quote
Old 09-30-2011, 11:36 AM   #2
acadianbob's Avatar
Here are my thoughts, others may have alternative viewpoints
1) Batteries are better off stored charged than discharged. So, leaving it plugged in is fine; assuming you have a 3-stage charger. I'm sure you do.
2) No, there is no discharge memory
3) It might not hurt to occasionally "exercise" your battery by discharging. BUT, you do NOT want to TOTALLY discharge it. A 50% discharge is acceptable; or bringing it down to approximately 12.0 to 12.1 volts. Then re-charge it immediately.
There is a thing called sulphation that can shorten the life of batteries that sit a lot; especially without being exercised. Your trailer charger will not address that issue. I use a product called a Battery Minder. This is what I use when the trailer is stored; the battery disconnected from the trailer. It has anti-sulphation technology and will keep your battery charged and conditioned. No personal interest in this product other than it works great. I have batteries that are 6 to 10 years old and still going strong; because of the Battery Minder IMO. Look at this link for useful information.
Camping/RV Battery Chargers | Battery Chargers by BatteryMINDers.com
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 09-30-2011, 01:19 PM   #3
wfmdfm's Avatar
Do you keep the battery in a non freezing area during the winter while you have the Battery Minder connected or do you have it out in the cold and connect it? Another question can you have more that one battery connected to the unit at the same time?
Wally
2011 Flagstaff 8528RKWS
2015 Toyota Tundra
wfmdfm is offline   Reply With Quote
Old 09-30-2011, 04:24 PM   #4
pattersonb's Avatar
Wally,
The battery is still in the RV. So far, we haven't had freezing weather (However, I live in northern Mich, and it's not far behind!). I will remove the battery for winter storage, and store it on a wooden platform in my furnace room. I'm going to investigate a suggestion on another post in this forum, and buy a Battery Minder. Thanks for your reply!
Old 09-30-2011, 05:04 PM   #5
I have left my batteries in my RV's for nearly 30 years with no ill effects. As long as the RV is plugged in, and the batteries are fully charged the batteries will not freeze. Leave them in, take them out? this debate has raged for years. If you feel better taking it out, then do it. But IMHO it is not necessary. When is the last time you actually saw or heard of a fully charged battery freezing?
Old 09-30-2011, 05:22 PM   #6
acadianbob's Avatar
Wally
Yes, I do put it in a non-freezing area; not sure you would need to. And depending on the model, most of them can do 3 batteries at once.
Old 10-01-2011, 08:16 AM   #7
Jeep4Two's Avatar
Originally Posted by pattersonb
Wally,
I would highly recommend not storing in the furnace room if you plan on keeping it on a battery charger of any sort. Charging batteries can release hydrogen gas, and if that builds up in an enclosed space and a spark ignites it..... Yikes!
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
Old 10-02-2011, 11:18 AM   #8
muzbomb's Avatar
What is the dry cell battery deep cycle like guys? I got the dealer to throw one in my RV as part of the deal.
Tow Vehical 2012 Dodge Ram 3500 Mega cab Longhorn SRW. White and Chromed out!!!!
Wife's ride 2008 Chev Tahoe, 22x10 Deep dish triple dipped chrome and black rims, Blacked out ride!!!!
2012 Wildcat 323QB
muzbomb is offline   Reply With Quote
Old 10-02-2011, 12:21 PM   #9
Herk7769's Avatar
I have to scratch my head here.
Please add some more information as to type and make of battery.
Do you mean Gel Cell? Closed Cell (maintenance free lead acid)?
Dry Cell batteries are like AA, AAA, C, or D and go into flashlights.
HAM CALLSIGN - KC3FFW
Old 10-02-2011, 01:38 PM   #10
muzbomb's Avatar
Not sure if this will help you out. 12V Dry Cell EV/Deep Cycle Sealed Battery, last longer than typical Deep Cycle Battery. That is what it says on there parts order list.
2012 Wildcat 323QB
battery
