Old 02-06-2014, 07:31 PM   #1
Camper Extraordinaire
shark918v's Avatar
Deep Cycle Batteries in Parallel
Q: Can a 12V marine deep cycle and a 12V golf cart deep cycle battery be connected in parallel?
shark918v is offline   Reply With Quote
Old 02-06-2014, 07:42 PM   #2
Rrickim63's Avatar
For optimum performance, batteries in parallel should be identical batteries and of similar date codes.
Sent from my LG-LS720 using Forest River Forums mobile app
2006 Roo 23B hybrid
2006 Ford F150 4.6L
Rrickim63 is offline   Reply With Quote
Old 02-06-2014, 07:46 PM   #3
shark918v's Avatar
I'm merely trying to see if I can extend the ability to use power when boondocking while conserving space.
Old 02-06-2014, 07:47 PM   #4
2007 WildCat 32QBBS
18CrewDually's Avatar
My concern is you would want to have the same Ah rating. If not the same amp hour rating, they won't charge evenly and one will draw down the other. I'd only use a matching set of batteries.
18CrewDually is offline   Reply With Quote
Old 02-06-2014, 07:51 PM   #5
Rrickim63's Avatar
Option 2 if you already have them. Use one at a time .
2006 Roo 23B hybrid
2006 Ford F150 4.6L
Old 02-06-2014, 07:52 PM   #6
Yes they can. I have been doing if for 10+ years on both 12Vdc Minkota trolling motors in fishing boat and sump pump backup 12Vdc motor at the house. Works great as it does what you expect, give you longer run time between charges Go overboard on the gauge wiring between the batteries so current can flow between them. Be advised the downside is if one battery craps out, it will take the 2nd battery down with it as they always are fighting each other to balance out capability. They are hooked in parallel after all. And as others said, use two of the same battery to get that balancing act between the two batteries.
SammySabre is offline   Reply With Quote
Old 02-07-2014, 08:10 AM   #7
Herk7769's Avatar
Dissimilar batteries have different internal structures and resulting different internal resistance. Connecting 2 dissimilar batteries "will work" but the charge/discharge cycles will be radically different resulting in reduced capacity of the pair and much shorter battery life for both.
Even small differences in resistance across the bank can result in poor overall performance of the stack. Interconnecting wires between the batteries must be as close to exactly the same length and gauge as possible, for example. Note also the the ground wire of the charge/load goes on one battery and the positive wire from the charge/load goes on the other in order for the internal connecting wire resistance to be the same.
File Type: pdf How to correctly interconnect multiple batteries to form one larger bank.pdf (106.1 KB, 62 views)
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
battery
