Old 09-25-2013, 11:31 PM   #11
Taranwanderer's Avatar
Les,
Yes, the charger I purchased is for both maintaining and desulphating any 12v battery. This is the one:
BatteryMINDer Onboard Battery Charger/Maintainer - 12 Volt, Model# 12151 - Amazon.com
At 1.5 amps, it could overcharge the battery if left on too long, except that it's also a smart charger that knows when the battery has reached full voltage and tapers the charge off to prevent overcharging. The Amazon reviews of the product were also very helpful in learning how it works. Hope that helps clarify.
At any rate, it seems the consensus is to flip off the battery disconnect while desulphating to prevent any converter issues or damage, so that's how we're gonna play it. Thanks, all!
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 09-30-2013, 04:30 PM   #12
wlhpas's Avatar
Send a message via AIM to wlhpas
does anyone know the size of the converter and inverter used in the Crusader 290rlt?
Days camped 2012 - 73; 2013 - 58; 2014 - 41
Days camped 2015 - 17
Bill and Pamela Hancy
TV: 2015 Ford F-250
RV: 2013 Crusader 290RLT
wlhpas is offline   Reply With Quote
Old 10-01-2013, 06:46 AM   #13
Send a message via MSN to Monterra
And in a 2 battery (parallel) configuration, hook up the Battery Minder/Tender to charge both batteries simultaneously?
Good judgement comes from experience........
Experience comes from bad judgement!!!!
'10 2304 Mini Lite
'14 Honda Ridgeline
Monterra is offline   Reply With Quote
Old 10-01-2013, 08:07 AM   #14
I would think you might be able to find this info either in your manuals, or in an online spec sheet, or your dealer (admittedly, not likely.) Sounds like a new thread!
That's a good question! Sounds like a call or email to Battery Tender's customer service to see what happens if their device is hooked up to 2 batteries in parallel--or maybe an answer from Lou?
Old 10-01-2013, 11:21 AM   #15
Triguy's Avatar
Monterra, the short answer is "yes".
Long answer: Batteries connected in parallel (positive to positive, negative to negative) are seen by the charger as "one" large battery of the combined amp-hour capacity of both batteries (Voltage stays the same while capacity increases). A properly sized charger will charge both simultaneously.
It is important you make sure that both batteries are the same size (same amp-hour capacity) and age. Since they will act as one when in parallel, they will try to balance out if different sizes/condition. One may be overcharged and the other undercharged.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 10-01-2013, 03:52 PM   #16
Triguy, what would you consider a 'properly sized' charger for 2 - 12 v batteries in parallel. They are new Interstate 'combo' batteries (RV/Marine - 550 CCA).
Also, does anyone have a recommendation for a desulphator. I was going to get a Battery Tender but that unit does not have desulphating capability.
'10 2304 Mini Lite
'14 Honda Ridgeline
Old 10-01-2013, 04:12 PM   #17
See my Amazon link at the top of the page--that is a 1.5A charger from Battery Minder that DOES desulphate.
Old 10-01-2013, 04:54 PM   #18
Triguy's Avatar
For chargers other than BatteryMINDer...
Can you provide the 20-hr amp rate (if possible)? This rate might not be available since these are marine batteries. Just FYI, but the CCA number won't help here as CCA is a measure of how well the battery can start an engine in the cold but not a useful measure for our needs in powering a camper. You need the 20-hr amp rate or, at least, the reserve capacity.
Basically, with the 20-hr rate, there are a number of ratios put out there by different companies. Usually, they will say something like "flooded batteries can accept a charge rate of between 10-13% of capacity (Trojan says this).
Interstate says "up to 10% of capacity" (source). Capacity is the 20-hr rate so if you only can find the RC, than Interstate has a rough formula for turning that number into the 20-hr rate. For example, an Interstate battery with the part number MT-34 has 120 minutes reserve capacity. In order to calculate the amount of amp-hours in a battery, the rule of thumb method is to multiply the reserve capacity by 0.6. In the case of a MT-34, 120 minutes reserve capacity multiplied by 0.6 = approximately 72 amp-hours (at the 20-hour rate).
BatteryMINDer is different in that their chargers are 8amps or less. If you get a batteryMINDer than I suggest that you call them.
I hope that helps you. I know its not a direct answer, but its all I got.
Scott
2012 Shamrock 233S
battery, converter
