Old 10-03-2016, 11:15 PM   #1
Did a "Boy Howdy" today pulled the harness out of the hitch pin box recepticle
Well I guess after all my years of towing,it was bound to happen,discounted from the trailer and the hitch box pig tail got caught in between the bed and the tail gate,and rip right out of the pinbox receptitcle.So I have 8 wires,and many wires that are coming out of the trailer,some twist together to align into one coming out of the box.Any suggestions on how to rewire this back,also the breakaway pulled loose as well.
2016 Forest River Heritage Glen 337BAR,towed with a 2015 Ram 2500 CTD,LoneStar Edition.
Bravo67 is offline   Reply With Quote
Old 10-03-2016, 11:33 PM   #2
Left Coast
Google 7 pin trailer connector...
Bob/Linda, 99 Dodge 2500 Cummins,2010 8280 Rockwood Ultra-lite 5er, PullRite Superglide----- I'm retired......but work part time as a pain in the ass!........... USMC.
bob caldwell is online now   Reply With Quote
Old 10-04-2016, 07:46 AM   #3
I am following you on that,a bergman 7 pin.But my problem is the wires coming from the trailer do not match up in color to the 7 colors on the harness coming out of the hitch pin box recepitcle.Plus the emergency brake control also is different in color as well.So not sure which wire it ties into.
Old 10-04-2016, 09:58 AM   #4
Head Rambler
Yeah, they don't follow the conventional wire colors once it leaves the umbilical. You'll either have to ring them out with a multimeter or have someone with the same model and year look and see what the colors are.
You could post a picture of the wires in the box and maybe it would match someone else's color scheme.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 10-04-2016, 03:34 PM   #5
mike.t's Avatar
Run a hot to each one and see what happens
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 10-04-2016, 03:41 PM   #6
Left Coast
First, find which one is the ground, in pig tail and trailer. Then make you a jumper wire with a couple small alligator clips and, leaving the ground alone, turn on tv park lights, find that wire on tv, then using jumper, connect to trailer wires, one at a time, till clearance lights come on......then, one by one, do the same thing....
Old 10-04-2016, 06:44 PM   #7
I just did the same think with my new 377FLIK. Boy did I feel stupid.
The following might help:
Truck Trailer
Pin 1 - Red, Left turn/Brake Red
Pin 2 - White, Ground White
Pin 3 - Blue, Electric Brakes Blue(light)
Pin 4 - Green, Running Lights Green
Pin 5 - Black, 12 VDC Return Black
Pin 6 - Brown, Right Turn/Brake Blue(dark)
Pin 7 - Yellow, Reverse Does not have reverse lights
Breakaway two wires (Black and Orange). Hool one wire to the Black Wire and the other to Blue for the Electric Brakes.
I used heat shrink and solder to make good water tight connections.
I pull the 377FLIK with a Ford F250 Turbo Diesel 4X4 Platinum. I may not be an exact match but it will get you started.
Good Luck!
Semi-Retired is offline   Reply With Quote
Old 10-04-2016, 10:19 PM   #8
Semi-retired,yea a boy howdy is fun ain't it.Forest Rivers tech support sent me the wiring diagram for the harness for the hitch pin.Thank-you for those pin postions,it concurrs with theirs as well.Also I only have light Blue so is this for both dark blue and light blue I am assuming.One other thing is that I have a white with a purple line wire .I am trying to fiqure were that with as well.Click image for larger version
Old 10-05-2016, 09:19 PM   #9
Wow,finished.No more Boy How do you do for me any more,hot weather,insects flying all around,dosed myself with deets,gee can it get any better.Gotta love summer's in Texas,almost over through only got to 87 today,nice breeze at the end to finish it up.Thanks everyone for the encourgement,and tech advice.
Old 10-05-2016, 09:44 PM   #10
mike.t's Avatar
It really wouldn't be any fun if it was always easy. Great job. Buy yourself a beer.
2015 Salem 27RKSS
55' Chevy Bel-Air
hitch, led
