Old 05-30-2016, 11:52 AM   #1
Did my surge protector fail?
I had the surge protector connected, E0 everytime I checked it. Went to disconnect the MH cable and I couldn't get the plug to come out. After much pulling and wiggling it gave way and the plastic at the prong was melted. We never lost power, protector never tripped.
ID:	109567   Click image for larger version
Kristina
2016 Rockwood Premier 2317G
2021 F150 XLT
Previously:
2005 Fleetwood Seapine, 2012 Rockwood Roo
2015 Sunseeker, 2017 Fleetwood Pace Arrow
hockeytownmom is offline   Reply With Quote
Old 05-30-2016, 12:15 PM   #2
I wouldn't say that your surge protector failed. It looks to me like one of your legs had a less than optimal connection and overheated.
David, Sherry and our three fur kids, Nicholas, Finnegan and Bentley
2013 Coachmen Encounter 36BH
2014 Honda CR-V/ Blue Ox Patriot II
DSurette is offline   Reply With Quote
Old 05-30-2016, 12:48 PM   #3
Timex's Avatar
I would say that you might not have had the plug twist locked in place enough. I am also a firm believer of making sure the prongs are clean and shiny and have a good film of dielectric grease on them.
I also wind up with some grease on me too!
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 05-30-2016, 12:50 PM   #4
Is this an easy fix?
Kristina
2021 F150 XLT
Previously:
Old 05-30-2016, 01:22 PM   #5
Timex's Avatar
First of all, you need to determine why the plug melted.
Was it twist-locked properly?
Were you drawing too many amps?
Was the power supply adequate for what you were demanding?
Was the power cord snugly plugged into the surge protector?
Were the pins bent so as to not make a proper connection?
Was the pedestal receptacle poorly maintained?
You will have to get the piece out of the MH receptacle by disassembling it somehow(doesn't look too difficult) and most definitely either put a new end on the cord(by a qualified person) or better yet, buy a new cord. I know, I know, these things are expensive but that's what money is for.
Old 05-30-2016, 04:37 PM   #6
Everything from the receptacle looked good, watts from it was good. I was on a 50 amp site running 30 amps with a dog bone. I would bet money the connection was poor because my husband has no patience to make sure the twist lock is threaded properly.
Kristina
2021 F150 XLT
Previously:
Old 05-30-2016, 04:53 PM   #7
clr
I would say that you had a light (poor) connection at the melted location. You will need to purchase a new connector and cut the old connector out and re terminate the wires properly. If you are not comfortable doing this have a professional do it for you. Clean the contacts in the future and make sure they are tight and you should minimize this happening.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 05-30-2016, 04:56 PM   #8
northstar1960's Avatar
for sure replace that cord end . no need to buy a whole new cord . that would be a big waste of money and the plug ends cost enough as it is . easy replacement for most anybody that can operate a screw driver and are not color blind . that was caused by a bad connection . arching was going on and caused the heat to melt the plastic
northstar1960 is offline   Reply With Quote
Old 05-30-2016, 05:38 PM   #9
You may have been pulling more than 30 amps and you MH breaker didn't trip. This is the breakers job and not the surge protector. I would have that breaker looked at when you are replacing everything else.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 05-31-2016, 07:43 PM   #10
Mrpsyko's Avatar
Poor connection
Looks to me like it was a poor connection either at the receptacle or your plug, I would just replace the plug, it is very easy to do.
Mrpsyko is offline   Reply With Quote
Old 06-09-2016, 03:04 PM   #11
I got a quote from a local RV shop. 300.00 total for the plug, cord and labor. I went to Camping World today and bought both for 100.00 or so. I'll install the new plug myself. I also bought the lubricant.
Kristina
2021 F150 XLT
Previously:
Old 06-09-2016, 07:18 PM   #12
Timex's Avatar
Good deal!
Old 06-25-2016, 01:32 PM   #13
I fixed it on Thursday and camping in it today. It was very easy!
Kristina
2021 F150 XLT
Previously:
