Old 03-06-2016, 08:54 AM   #1
MN SNOWBIRD
Question Dim 12v lights in bathroom
Anyone out there have knowledge concerning 12v weak and dim lights in bathroom of 38FL Cedar Creek 5er? All other 12v systems are working fine, including all other lights throughout. But, these 2 lights are barely working. They must have power because they turn on, but are extremely dim. Are they wired so if one is faulty it affects all in the same room?
Larry and Bette
2015 Cedar Creek 38FL 5er
2013 SRW Ford F350 8FT box
Work is OK but retirement is much better!
MN Snowbird is offline   Reply With Quote
Old 03-06-2016, 10:14 AM   #2
I would take a look at the switch.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 03-06-2016, 10:18 AM   #3
AquaMan's Avatar
Check voltage at switch and at light. Most likely a loose connection, but have heard of the lights actually melting.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 03-06-2016, 05:20 PM   #4
Check connections....
Sounds like a grounding problems but bulbs can go bad. Did you try a new bulb?
mfMcFroggierPod is offline   Reply With Quote
Old 03-07-2016, 11:56 AM   #5
rlsmith's Avatar
Lights may have 2 way switch at fixture. ... night light and bright light
Days Camped: (2014: 24-(final), (2015: only 19 due to bad storms in spring then got busy with DW honey do list-(Final), (2016: 31 (final), (2017: 10 (final )
rlsmith is offline   Reply With Quote
Old 03-07-2016, 12:02 PM   #6
Check for loose ground connection.
Harkerr is offline   Reply With Quote
Old 03-07-2016, 01:26 PM   #7
Are the lights the round, recessed LED's? If so, they may be going bad. I've had to replace almost all of them in my CC38RD. FOREST RIVER has been good about sending replacements.
Rollingdunder1 is offline   Reply With Quote
Old 03-07-2016, 05:26 PM   #8
Mrpsyko's Avatar
I would check the connector on the fixture wiring and the connections on the switch. I had one of my light go dim then out, when i pulled the fixture down I found the crimp on wire connector was not crimped properly and was melted.
Mrpsyko is offline   Reply With Quote
Old 03-08-2016, 08:40 AM   #9
MN SNOWBIRD
Read new thread on this subject dated 3/8...Do You have Defective LED
Larry and Bette
light, roo
