Old 02-14-2015, 12:43 PM   #1
Exclamation dim led on furrion main power connection with vid
I think its moisture causing this little led to act up, any input will be helpful. As soon as I touch the metal cover lightly it goes out telling me im taking the current from it with my body. Shaking or wiggling wires does not affect it. Any other ideas??
2006 Honda Goldwing
2012 Toyota Tundra DC s(sold)
2015 Cherokee Grey wolf 19RR Limited
2017 F150 Super Crew 3.5eb 5.5
bluewoo is offline   Reply With Quote
Old 03-14-2015, 01:50 PM   #2
Just an update. I took it all apart and the resistor is bad so I'm going to fix this my self. Not much behind the cover just this.........so anybody wants to know - now you do!
Moisture was the culprit.
ID:	71302   Click image for larger version
2006 Honda Goldwing
Old 03-15-2015, 05:15 PM   #3
Can anyone help me find this resistor? Its a 10.5k metal film any advice would be appreciated.
I dont need to buy a 20 pack and im not sure about the wattage 1/4 - 1/2 ??????
2006 Honda Goldwing
Old 03-15-2015, 05:22 PM   #4
fonzie's Avatar
NTE QW2105BR - 1/4W 10.5K OHM 1% METAL - Radioshack
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 03-16-2015, 09:17 PM   #5
Learjet's Avatar
Radio shack, eBay...,Google 😃
-2017 Ram Cummins, Aisin DRW 3.73, 4x4
-2015 Wildcat 317RL
-B&W Companion , MorRyde pinbox
Learjet is offline   Reply With Quote
Old 03-18-2015, 07:52 PM   #6
update
ID:	71675Did some research and fixed it my self with a 100k ohm 1/2 watt resistor and new led lamp(radio shack that was still open). I think the resistor or led was bad. Really not water resistant either since hot glue was used from assembly - now it sealed with silicone.
Thank for the info
2006 Honda Goldwing
Old 03-20-2015, 08:35 PM   #7
Alberta8311ss's Avatar
Mine did the exact same thing! Opened it up and found water damaged both led and resistor. I did a similar fix and then coated it in silicone and reassembled.
Alberta8311ss is offline   Reply With Quote
Old 06-03-2016, 08:54 PM   #8
khocke's Avatar
Bluewoo, Alberta: how'd you open up the cover to get to the electronics? I removed the 4 phillips and got the hinge cover off. Now what? Peel back the gasket or pry off the outside brushed steel escutcheon?
khocke is offline   Reply With Quote
Old 06-03-2016, 09:57 PM   #9
Remove foam gasket if i remember right.
Old 06-03-2016, 10:34 PM   #10
raspivey's Avatar
My 2104S died shortly after I got it...never bothered fixing it. I may have to see about waterproofing the next one when it gets here as it looks to be the same design. Does it look like just pulling the gasket and silicone sealing it will work?
power, led
