Old 05-22-2019, 06:30 PM   #1
Dimensions Unlimited Inverter
I have a DUI 12W6T that is giving up what is a good replacement?
melesprocnc is offline   Reply With Quote
Old 05-23-2019, 09:53 AM   #2
I can't find that model anywhere. How many watts is it?
Gotta go campin!
Old 05-23-2019, 09:58 AM   #3
600 watts
Old 05-23-2019, 10:04 AM   #4
Check out Amazon. More choices there than you can imagine.
Just filter by best reviews. Competition had driven prices down over the years where you can buy a good 1,000 watt inverter with 2,000 watt "Peak" output for what a previous generation 600 Watt True Sine Wave inverter cost.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change)
Old 05-23-2019, 10:11 AM   #5
Ask yourself what you use it for. If it's an occasional tv show then about any inverter will do. If it's pretty constant usage for something critical then I'd step up to a pure sine wave inverter. I'd probably also increase the capacity to about 1000 watts as Mike eluded to above.
Gotta go campin!
Old 05-23-2019, 10:29 AM   #6
This thing multi tasks it's plugged into the 110v system and converts to 12v and inverters to 110v I disconnect the batteries when I'm plugged into a 110 volt supply
Old 05-23-2019, 01:02 PM   #7
So it's an inverter/charger?
I still can't find anything under that model number.
There's Xantrex of course then Magnum. You could always go back with a Dimensions/Magnum unit.
Gotta go campin!
Old 05-23-2019, 04:15 PM   #8
rk06382's Avatar
I love my Samlex EVO-2212 Inverter/Charger.
>They have great customer support.
>It is made in Taiwan.
>It will surge to 6,000 watts.
>It has two AC inputs, Shore & Generator.
>It has a 100 amp DC charger built-in.
>It is like having a UPS for your Motorhome.
I could go on.......
Robert
2018 FR3 28DS | Boondock 99% of the time
Samlex EVO-3012 Inverter/Charger | 600ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | SnapPads | SumoSprings | Koni Shocks | RVLock
Solar Power & Battle Born batteries
rk06382 is offline   Reply With Quote
inverter
