i have a 2011 cedarcreek 36 re. the 12 volt ceiling lights keep flashing dim and brite, then might stay bright or dim. then go go back to normal. put a new wfco 65 amp converter in last summer. i can't figure it out, help!
pull all the fuses[12v] except for the lights, wait and see if lights dim and brighten. now start replacing fuses one at a time till dimming problem reoccurs. that circuit is your problem
Had the same issue back in early March. Problem was the converter was overheating / bad. Replaced converter, no issues now. Get a Progressive Dynamics not a WFCO.
2011 Palamino Sabre 31RETS
2006 Ford F-250 Super Duty 6.0L
