Originally Posted by RVPP
Thanks for the help. I just ordered a CRC product for cleaning. Took a while to put a name to the plug and socket, 7 way seems to be the winner.
Thanks again for the help.
Paul & Cindy
R/V Waldo
CRC will be fine. I use that and another called Corrosion Block, which does basically the same thing, on marine electrical systems. Backs of switches, fuse blocks etc. works really good for cleaning and protecting. Less mess than dielectric grease in the long run, although that's some good stuff too. Some marine generator manufacturers actually recommend spraying the entire genset to prevent corrosion. There's plastic, metal, paint, and all kinds of stuff in there.
2013 Solaire Eclipse 317BHSK 2009 Denali XL Tow Vehicle with Equalizer distribution and sway control
