Old 10-23-2013, 07:36 AM   #1
BuckeyeChuck's Avatar
Disconnect battery?
When wintrerizing is it okay to just turn the battery switch to the "off" position or is it necessary to disconnect a cable?
2012 F250 Super Duty
2013 Sabre 33CKTS
BuckeyeChuck is offline   Reply With Quote
Old 10-23-2013, 07:48 AM   #2
Best thing to do is remove the battery and store it inside your garage/basement, etc.
Old 10-23-2013, 08:04 AM   #3
Just turning the switch should be sufficient.
You probably need to put some charge in the battery about every 6 weeks or so. If you won't be able to do that at the RV, then I agree that you probably should take it home so you can.
Old 10-23-2013, 08:16 AM   #4
AKA: 'tiredTeacher
awellis3's Avatar
I'll third that. Mine sit in the basement on a Battery Minder all winter. We use our TT exclusively in the winter, so the pop up is winterized, blocked and covered until the end of April.
Teach
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 10-23-2013, 08:26 AM   #5
X4. No sense leaving in out in the Michigan cold. Make sure you note the correct cable connections before you remove it.
Old 10-23-2013, 09:04 AM   #6
acadianbob's Avatar
You can bring your battery in from the cold if it makes you feel better but there is no need. The real secret is to put a battery minder on the battery and to disconnect if from the trailer. You should do the battery minder whether it is in warm or cold storage. This keeps the battery in top condition without overcharging. It also provides anti-sulfation technology.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 10-23-2013, 09:13 AM   #7
Denver, CO
garbonz's Avatar
X2, HOWEVER, some units still have some systems connected, so I would check your battery voltage once in awhile until you are certain it is not getting discharged.
Batteries weather well in the cold if they are kept fully charged, which means you should put a charger on them once a month to be safe.
It is best to put them in the basement or garage, with an occasional charge, but batteries are heavy and my back is tired so I leave them in and have had no problem with them lasting along time with occasional charging. IMO, of course
2017 Fuse 23T
Old 10-23-2013, 09:17 AM   #8
Originally Posted by garbonz View Post
X2, HOWEVER, some units still have some systems connected, so I would check your battery voltage once in awhile until you are certain it is not getting discharged.course
Learned this the hard way. The power jack is still connected when the disconnect switch is off and there is a little light on my power jack when it is turned on. The light is hard to see on a sunny day. So I forgot to turn off my power jack, didnt see the light, and came back a couple days later and battery was dead.....
2013 Rockwood Mini 2503S
2011 Chevrolet Silverado 1500 5.3L
Bryan2503S is offline   Reply With Quote
Old 10-23-2013, 09:42 AM   #9
KyDan's Avatar
Some battery disconnect switches disconnect everything, some don't.
Mine does (except the emergency break away pull cord) and I keep
them in the trailer but they are on a battery tender Jr so they are always
topped up. If you have power available at your storage or parking spot
I highly recommend a battery tender-- even if your batteris are sitting in your
house or garage they should be on a tender.
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
Old 04-14-2014, 06:15 AM   #10
I got my camper out of winter storage last Wednesday. When I put it away last fall I just turned off the battery switch. I foolishly started this post AFTER I put it away for the winter. Still had plenty of battery power when I picked it up. I was concerned because I needed to be able to retract the landing gear once hooked up, but all was well. This was a real cold winter here lots of sub zero temps. I like the battery minder idea but I winter store in a HUGE building and have no access to electric outlets. I didn't know what I'd find when I picked it up. Maybe I got lucky. In the past I never removed the battery but would disconnect the cables.
Sent from my Nexus 7 using Forest River Forums mobile app
2013 Sabre 33CKTS
