03-13-2016, 11:53 AM
Disconnected wire under wheels
2013 Vibe, I have a disconnected wire under the wheel, could be breaks or lighting? Are the wire connections a standard color, ie green breaks, red lights etc, or other ?
03-13-2016, 12:14 PM
Under the wheel? Do you mean behind the behind the wheel coming out of the brake backing plate? If so ... there should be two wires coming out of the backing plate behind each wheel ... they are for your brakes. They should connect to two other wires coming out of the axle or above the belly. There is no polarity to these wires.
03-13-2016, 12:24 PM
That sounds correct., 2 green wires. Will check other side. Took a quick look today but the rain started coming down, so packed it in. What does the breaking plate look like ?
03-13-2016, 12:27 PM
You will hear brakes hum if you stand next to them and have someone hit the brakes in TV.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
03-13-2016, 12:31 PM
Also if you know, are these separate from break lights indicators? Will the break lights work if the breaks are not connected ?
03-13-2016, 12:41 PM
Yes brakes and brake lights are different circuits.
So yes brake lights will work even if brakes are not working or vice versa.
Hensley Arrow
03-13-2016, 12:45 PM
Brake lights will not be under trailer near wheels. Just clean the wire good and reconnect. I prefer soldering then insulating, but if you can't do that. Use wire nut and once you verify connection, fill wire nut with silicone and tape after silicone drys
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
03-13-2016, 01:05 PM
The brake wires on my TT are green, more than likely the same on yours.
2007 Surveyor SV230 - 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
03-13-2016, 01:10 PM
Don't think you will hear a "hum" with DC current.
You may hear a faint click as the electro magnet is pulled into the brake drum when the brake is activated.
03-13-2016, 01:21 PM
An easy test to see if you are getting power to the brake magnets is to hold a compass at the wheel. Have someone press the brakes in the tv. If the needle on the compass "dances" you are ok. If not, you have a problem. Do each wheel this way.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
03-13-2016, 03:10 PM
"Backing plate" is just the round stamped steel plate on the end of your axle behind the brake drum.
05-14-2016, 04:20 PM
I was able to solve the problem. I did repair the wires with the proper connectors. You can hear brakes hum if you stand next to them and have someone hit the brakes in TV. The side that was connected we could hear, and the damaged wire we did not hear. So the brake hum showed it was reconnected.
05-14-2016, 04:53 PM
Thank you for the follow up.
Happy Camp'n !
05-14-2016, 05:40 PM
X2
We love it when you come back and let us know what the problem was and what the fix was.
Gotta go campin!
