07-11-2016, 04:03 PM
DO NOT DISCONNECT your co detector.
Even tho you may want to DO NOT make it shut off with a battery disconnect switch!
Last week ms Amy asked jonalyn our 19 yo daughter to go to the camper and shut off the fridge and unload it, which she did.
Hours later I came home to hear the loudest beeping I've ever heard coming from the camper.
When I opened the door I was totally overcome with propane fumes.[emoji15][emoji15][emoji15]
While unloading the fridge she bumped not one but two stove burner knob turning them on when she exited!
Now had the propane detector been turned off via a disconnect and I had turned it on it could have been disastrous!
About 30 lbs of propane had filled the camper.
FYI I'm still here to tell you about it.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "14"
07-11-2016, 04:05 PM
YIKES! It gives me the willies when I read on here: "I got tired of it beeping so I just cut its wires."
07-11-2016, 04:09 PM
I wasn't concerned at first but when I thought about it i was omg that could have been very very bad!
2015 Columbus 320RS
2008 2500HD Duramax
07-11-2016, 04:11 PM
WOW. That is why I hate to hear it called a low voltage alarm when it is really a "your propane detector is not functional alarm".
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
07-11-2016, 04:25 PM
x2!
Glad this had a happy ending.
Formerly owned 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab
07-11-2016, 05:07 PM
Originally Posted by TURBS
Even tho you may want to DO NOT make it **** off with a battery disconnect switch!
I did this same thing. Of course we are supposed to turn off the propane at the tank but it is any easy thing to forget. Also turn off your propane grill at the tank when not in use. Not only could you bump the burner valves open but small children could play with them.
2015 GMC Sierra 1500
2013 Heartland North Trail 28BRS
07-11-2016, 05:24 PM
So glad you're okay, Turbs! No one needs a leveled RV and, especially, loss of life! This is a super reminder that these are put in RVs for a reason!
07-12-2016, 06:55 AM
Damn that's scary. Glad to hear everybody is OK.
07-12-2016, 07:13 AM
I'm still here!
Y'all goin to have to put up with me awhile longer!
2015 Columbus 320RS
2008 2500HD Duramax
07-12-2016, 07:30 AM
Hey, we have some golf cart procurement to do at Goshen this year! Stay safe!!
B and B
07-12-2016, 07:42 AM
WOW!!!! Glad you found it before something happened, always nervous with gas and double check all the time but things happen, glad it turned out good.
07-12-2016, 07:57 AM
That is very scary indeed! Thankfully everyone is ok.
07-12-2016, 12:54 PM
Glad you are all okay--- that could have been TRAGIC!!!
Thanks for the valuable warning!
07-12-2016, 01:15 PM
oh maybe 6-7 years ago i was down by the lake with the kids and kept hearing a beeping alarm and just thought "come on neighbor, turn that off its annoying". As i came up from the lake towards the camper i noticed it was coming from mine. This was one of the first trips with a TT after years of having a old pop up and i was still learning. Same thing as you mentioned, instant breath of propane due to stove being on.
I will never forget the fact i had no idea what the alarm was and REALLY glad i tossed the cigarette butt in the fire pit before opening that door.
Thanks for passing that along!!!!! Glad everyone was ok.
All too often safety devices of all types get bypassed, overlooked, taken off, there are important reasons things are made and there as they come from the factory.
All to often we tend to think it can't happen to me but the plain fact is it can and does......... and we go on the defensive to justify why we do the things we do.........
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
07-12-2016, 02:51 PM
The propane detector in my 2011 Georgetown 327DS is also hooked to a solenoid valve in the gas line at the propane tank. If the detector goes into "alarm" mode, it shuts off the propane at the tank.
At the recommendation of an RV technician, I installed an SPST switch in that line which gives me a mechanism to turn off the propane at the tank from inside the RV. With the switch off, there's no propane in the lines once they leave the tank area and the solenoid doesn't draw 12V power from the house batteries. After I burned out two internally lit switches, I wired an LED into the circuit to let me know when the solenoid was powered.
Phil
07-12-2016, 03:06 PM
If you simply turn of your gas bottles when you turn off your battery, this would not be a problem.
2011 Traverse LT, 3.6L, FWD
07-12-2016, 03:54 PM
Until you forgot [emoji6]
2015 Columbus 320RS
2008 2500HD Duramax
07-12-2016, 05:41 PM
2015 Columbus 320RS
2008 2500HD Duramax
Might as well remove your battery disconnect switch, then. Leaving the CO/propane detector on will still kill the battery. Especially if you're like me and have to store it in a storage lot.
07-12-2016, 05:59 PM
This is one of the reasons we have always used a checklist. It’s too darn easy to forget something important, especially when you have to keep the RV on a storage lot the way we do. Regardless, mistakes can still happen.
I'm glad nothing bad happened Turbs.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
