Old 01-07-2016, 12:03 PM   #21
Originally Posted by VinceU View Post
"The converter should supply more than enough power to operate the slide motors. This slide motors will run from either the 12 V DC"
In case of hydraulic slides this may not be accurate. Lippert fuses the motor to 120 amps! Way over the converter rating of max 55 amps. A few operations w/o a battery you may be shopping for a new converter.
They are fusing two to three times running amps to cove a surge. Remember fuses blow instantly at their rating. They don't ever expect the pump motor to draw that kind of load. That motor probably draws about 30 to 35 amps under normal load.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 01-15-2016, 09:28 AM   #22
If I use the factory battery disconnect on our new Lacrosse the slides will not operate with the trailer plugged in. I would guess that on ours anyway they do not want the slides operating with out a battery pressent. Everything else in the trailer works, 12V and. 120V with battery disconnected.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
Old 01-15-2016, 09:58 AM   #23
AquaMan's Avatar
Have not seen any hydraulic units fused to 120 amps. My Sierra with 4 hydraulic slides and landing gear, came from factory with auto resetting breaker of 20amps. Wasn't quite enough to run without tripping 3-4 times, so replaced with a 40amp and never had trouble again.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 01-15-2016, 09:44 PM   #24
VinceU's Avatar
Iggy has published a 12 VDC diagram for a Georgetown. Mine was the same, some had 120 amp circuit breakers others 100 amp breakers. The heavier the coach, the more power (amps) required to lift and level.
Inadvertently doubling the ampacity of any circuit is root cause for a fire and not covered by an insurance policy.
VinceU is online now   Reply With Quote
Old 01-19-2016, 09:26 PM   #25
Too Tall's Avatar
Does anyone know if it's safe to charge the RV battery with a portable charger without damaging any of the RV circuitry if the disconnect switch is off? I guess I'm asking, does the disconnects switch on my rockwood TT completely isolate the battery so an external charger could be used instead of the onboard converter/ charger? thanks in advance.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is online now   Reply With Quote
Old 01-19-2016, 09:36 PM   #26
TURBS's Avatar
My question is why would you want to ?
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 01-19-2016, 10:20 PM   #27
2015 Columbus 320RS
2008 2500HD Duramax
Turbs my Q in your Post # 26 is it 31 or 34 Night's camped? Youroo!!
Old 01-20-2016, 10:41 AM   #28
Too Tall's Avatar
2015 Columbus 320RS
2008 2500HD Duramax
For quicker charge and de-sulfating the battery. But I'd probably take it off for de-sulfating.
USMC 68 -70
Old 01-20-2016, 10:50 AM   #29
Too Tall's Avatar
Originally Posted by prof_fate View Post
My camper is in storage (backyard) and the battery is in the house getting charged now and then.
Bought a small generator, due here this week, and want to try it on the camper.
Do I need to hook up the house battery to make things work? (slide in particular)?
What gen did you buy? I'm shopping for one.
USMC 68 -70
Old 01-25-2016, 09:45 PM   #30
Blackhat6mike's Avatar
Check Tractors Supply for a gen. They run some great deals from time to time. I've bought three Champions from them ranging from 2,000 watts to 4,600 watts. Paid $325 for the 4,600.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
battery, camper
