Old 09-08-2013, 07:09 AM   #1
Does Disconnect Switch Affect Charging
When my TT is plugged into 110 at home does my battery get charged if the battery disconnect switch is off?
Tent2TT is offline   Reply With Quote
Old 09-08-2013, 07:33 AM   #2
Witch Doctor's Avatar
Your battery will not get charged from your convertor if you switch off the disconnect. It will take the batteries out of the circuit.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 09-08-2013, 07:43 AM   #3
Whitewolf's Avatar
When I was getting the Walk About from the service tech when we bought ours, he pointed out the battery disconnect. I didn't know there was such a thing. It's not a topic of conversation around the fire.
"Hey, you got a battery disconnect?"
"No, do I need one?"
"I don't have one either."
"I got one."
"What's a battery disconnect?"
The conversation with the tech and me went something like this.
"...and here's your Battery Disconnect."
"What's a Battery Disconnect?" (see above conversation)
"When you store this unit for a period of time, pull (push, I forget) the disconnect so your battery doesn't get drained by things you might leave on or by the radio and things." ( a lot of radios have a clock display that's always on)
"I always leave our units plugged in when not in use."
"Then never mind."
Sooo, in answer to your question, it stands to reason to me that if I were to disconnect the battery from the rest of the electricals in the trailer to protect the battery, then disconnecting the battery will also prevent it from being charged. It'd be like removing one of the wires (preferably positive) from the battery itself.
I could be wrong though given the fact that I'm married.
A rainy day campin' is better than a sunny day workin'.
'13 Windjammer 3025W
'14 Ram 3500 w/6.7 Cummins
No dogs. No Cats. No kids. Just us.
Whitewolf is offline   Reply With Quote
Old 09-08-2013, 08:14 AM   #4
Mister's Avatar
Yep, isolates the battery for the converter and the 12V circuits inside the trailer. Battery switch needs to be ON for battery to charge on shore power.
Though some brands have taken to adding a direct circuit to the battery from safety devices like LP detectors. Also slide motors and electric tongue jacks are often not bypassed. So if you store your camper for an extended period (more than a month or so) without connection to shore power, it's best to disconnect the battery all together.
2008 F150 FX4 5.4L & 3.73s
2014 PTM Tracer 3200BHT
Yes...I've finally made it to Prime Time!
Mister is offline   Reply With Quote
charging
