Old 01-26-2016, 11:13 PM   #11
Usually Confused Member
emm-dee's Avatar
Shouldn't this type item be readily available? Can't find it on Amazon (and don't use eBay)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
emm-dee is online now   Reply With Quote
Old 01-27-2016, 01:02 AM   #12
MNtraveler's Avatar
The linked item is an example. It is available from multiple sources and manufacturers.
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 01-27-2016, 05:19 AM   #13
Oaklevel's Avatar
Might be OK since it is from progressive industries. I do know I have had issues with the small cheap "pucktype" 30A to 110V melting. I have never had issues with a quality dog bone type. I assume the heat build up in certain cases due to the connections being so close together can be an issue. Although I have never seen a 30A to 50A puck style. I use the bog bone type all the time in the summer as our camper now has two 30A style hookups. I use both the campground 30A and 50A plugs. But that is so I can run 2 ACs on a 30A trailer.
Maybe someone else will chime in but the biggest potential issue I see is two connections with a couple of inches of each other could be problematic. Heat build up? Personally I would not use one but I again know no one that has used one.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 01-27-2016, 07:04 AM   #14
Head Rambler
I'd have to say that it's no better, and possibly a little worse than a dogbone adapter. I say possibly worse because all connections generate some heat above the heat generated by the conductors, so with the adapter, you have two connections in close proximity of each other. With the dogbone they're at least spread apart a little.
In my opinion, the current configuration of both should be illegal. Both still use a 50 amp breaker to protect a 30 amp conductor. Ideally a 50 amp to 30 amp dogbone would have a 30 amp breaker inline. However, thousands of them have been used and I haven't heard of them causing a real problem.
Gotta go campin!
Old 01-27-2016, 07:16 AM   #15
AquaMan's Avatar
I see it as a "possibly" being worse in certain situations, where the outlet is worn slightly and the added length of the plug creates leverage against the outlet wanting to pull the plug free. Also, I have an extension cord that has a handle on the plug, making the length of the plug that much more to where the lid may not fold down all the way, possibly allowing wind to blow the lid up and and beat down on the plug. I say possibly in each situation. I like the dogbones.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 01-27-2016, 12:21 PM   #16
7 Year Class A RV'er
Only issue with the plug adapter is if the adapter with the shore cord plugged in sticks out too far to close the breaker box lid. Usually not an issue either way. I would suggest spending a little more for the PI brand adapter as some of the others are lesser quality. The one I used to have was sort of loose connecting to the cord, overheated and fused the end of my shore power to the adapter. Had to cutt He adapter apart to get it loose.
2015 Legacy SR340 360RB
Old 01-27-2016, 12:35 PM   #17
If your looking for a good connection without a lot of heat buildup, the dog bone is what you want. If you try them both , you will see the most adapter only plugs do not let the cable hang straight down whereas the dog one hangs straight and does not pull on the outlet at an angle.
hillsdaletc is offline   Reply With Quote
Old 01-28-2016, 08:18 AM   #18
Wolverine 1945's Avatar
If you care,,, Wally World sells a 30 to 50 amp adaptor for about half that price !!!
Wolverine 1945 is online now   Reply With Quote
Old 01-28-2016, 09:01 AM   #19
Always always only use a dog bone style as the adapter plugs have a very bad habit of going up in flames!!
Hope this helps Happy Camping
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
silverback 35ts is offline   Reply With Quote
Old 01-29-2016, 02:16 PM   #20
MNtraveler's Avatar
Thanks for all the comments. I'm going with the dog bone for the heat/safety issue and because when I plug my surge protector/EMS into a 15 amp adaptor and let it hang down, the weight of the EMS pulls the adaptor out of the socket. I need a very solid connection in each spot.
2016 Forester 2401R
