Old 12-03-2015, 12:54 PM   #21
Who Dares, Wins
doc73's Avatar
But the surge protector gets power before it is blocked so it (surge protector) can and will arc when it is plugged into the pole.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 12-03-2015, 01:18 PM   #22
TURBS's Avatar
The surge protector uses no power, so why would there be an arc?
Old 12-03-2015, 04:15 PM   #23
Who Dares, Wins
doc73's Avatar
It must use some power to light it's display and run it electronics.. Unless it is powered by kittens and corn pops.
EDIT: In case we are talking about different things... I have a PI surge and voltage monitor.. I must use SOME bit of power.. A straight old surge protector may not use anything, I have no idea..
2015 Chevy HD D-Max
Old 12-11-2015, 05:08 PM   #24
I am always extra careful when inserting The plug in the receptacle. That being said I wouldn't do so if breaker is readily available as it is in the pedestal.
It only takes a slight distraction to cause you to grab the wrong part of the plug.
Many that take up rving have limited experience around electrical circuit.
Better to advocate an SOP of always turning off breaker.
Just my $.02
2011 Solera 235S
Freightliner Badge
cousin01 is offline   Reply With Quote
Old 12-11-2015, 05:30 PM   #25
Turning off breaker at pedestal should be done before plugging in, but that only works IF the pedestal HAS a breaker, have seen lots at CG's that don't!!!
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 12-11-2015, 11:26 PM   #26
MNtraveler's Avatar
In that case, the SOP is plug the TT/MH side first then don't dawdle while plugging into the receptacle. Ready-aim-plug. Don't be thinking about where you left the f/w hose...
Some would say turn off the inside main circuit breaker first. I'd be interested in hearing opinions about that.
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 FR Forester 2401R
Towing 2014 Honda CR-V
MNtraveler is offline   Reply With Quote
