Old 05-17-2018, 06:07 PM   #1
TheBobster's Avatar
DOH! Accidentally reversed polarity
2012 FOREST RIVER 2043 MINI LITE
First time this year hooking up the battery. I didnít notice I placed the battery into the tray backwards. Got some sparking hooking up the ground connection. The two 40A reverse polarity fuses were blown.
After realizing I had reversed polarity and correcting it and replacing the 40A fuses, everything works except the water pump. The electrical panel pump switch light does not light and the pump makes no noise. I checked inside the control panel and all wiring looks okay,
I see references to an inline fuse or two but have not yet found any near the battery or in the pump compartment.
Anyone have ideas?
TheBobster is offline   Reply With Quote
Old 05-17-2018, 06:12 PM   #2
Flybob's Avatar
Check the resettable breaker under the tongue ( see Photo). Also look for a glass inline fuse in the water pump power line close to the pump.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-17-2018, 06:29 PM   #3
Don't bother looking for a resettable breaker under the tongue. If everything else (12 volt) works then that beaker is OK.
Check for a blown fuse in the converter area.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre - Tow Package
Boon Docking 99% of the time.
boondocking is online now   Reply With Quote
Old 05-17-2018, 06:50 PM   #4
Mr. Dan's Avatar
Water pumps generally have a fuse in-line - maybe 6-12 inches from the pump.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 0; booked = 14
Old 05-17-2018, 08:25 PM   #5
Duckogram's Avatar
Look for this...
ILB
Old 05-18-2018, 12:45 PM   #6
TheBobster's Avatar
Anyone have ideas?
FIXED PUMP ELECTRICAL
I dismounted the monitor panel and discovered the pump power switch had its power supply wire disconnected.
Old 05-18-2018, 01:04 PM   #7
Glad you found it and reported back.
Your finding though bears the question... how did the wire at the pump's power switch become disconnected?
Days Camped: '15=22 '16=46 '17=30 '18=51
Old 05-18-2018, 01:25 PM   #8
TheBobster's Avatar
I have the same question. Both the pump supply wire spade was disconnected and the multi-pin connector to the monitor board. Evil gremlins is the only logical explanation.
Old 05-18-2018, 02:05 PM   #9
Just as confused as you
Scrapper's Avatar
You know the gremlins just want to be loved, I blame the goblins.
Richard & Jill
Camping since 1989, seasonal since 2000
Car Shredder Operator/Technician, Scrap Metal Recycling - retired
Old 05-18-2018, 02:49 PM   #10
Bluepill's Avatar
Flux capacitor overload.
2018 Coachmen Freedom Express 192RBS
accident
