Old 01-11-2011, 10:11 AM   #11
KRS
KRS's Avatar
Pulled the interior access panel again.
Then removed a sheet metal cover on the furnace unit.
This exposed the burner tubes.
I took a bright flashlight and shined it back between the burner tubes and I think I can see a squirrel cage. Tried to thread an old fishing pole back there to turn the cage. IF that was the cage, I couldn't get it to budge. No mouse droppings anywhere.
KRS
2004 Forest River Wildcat 29BHS
15.0 BTU ducted roof air
Tow vehicle: 2006 Dodge 3500 cummins turbo auto
Cummins exhaust brake
Air bags
KRS is offline   Reply With Quote
Old 01-11-2011, 10:26 AM   #12
piscesman's Avatar
Here is a Suburban furnace overview that may be of assistance to you...good luck!
2003 GEORGETOWN 325
"NOT ALL WHO WANDER ARE LOST"
Nights camped in 2011: 108
Nights camped in 2012: 41
piscesman is offline   Reply With Quote
Old 01-12-2011, 07:51 AM   #13
KRS
KRS's Avatar
Just used a surefire flashlight to look inside the exterior vents.
There appears to be mud dauber nests in them, I can see a bit of squirrel cage and the nest looks like it's attached.
Thought about removing furnace to clean it. There are two screws attaching furnace to trailer. There is a propane connection. Then there is a bunch of wires. The wires have no quick disconnect.....
Air bags
Old 01-12-2011, 07:59 AM   #14
KyDan's Avatar
Yep. Sounds like you're on the right track.
Welcome to RV maintenance 101.
Good luck!!
Peace!
Dan & Rita D
Blue Ox WD hitch
KyDan is online now   Reply With Quote
Old 01-12-2011, 08:13 AM   #15
KRS
KRS's Avatar
Here's the setup (in the Arizona mountains August '09)
Air bags
Old 01-12-2011, 08:43 AM   #16
RV Newbie
buzzards27's Avatar
unless you can get to the nest thru the tubes from the exterior with a crevice tool pulling the unit is the best.
handle the furnace carefully. i had mine out last fall and discovered out on the road that i had somehow cracked the insulator on the electrode. crack was right where the insulator passed thru the mounting bracket so electrode was shorting out and the furnace wouldn't light. there we were 250 miles from home, 9 o'clock at night and miles from a town in 25 degree weather and there i am tinkering away to rework the electrode to get heat. fortunately, we were using a space heater and only needed the furnace as a back up.
2005 FR Lexington 210 6.0L 8500 miles
2007 2500 Silverado Ext. Cab, 6.5' bed 5.7L
2010 Ford Fusion Hybrid
1963 Ford 861 5 speed with loader
1958 Ford 800 Select-O-Speed (parts tractor)
buzzards27 is offline   Reply With Quote
Old 01-13-2011, 08:36 PM   #17
KRS
KRS's Avatar
It's a Suburban SF-30F.
Pulled it today.
Ruined the dual chrome exterior vent... can't seem to find one...?
Do I use the 'ribbon' style sealant to put the vent back on?
Okay, pulled the furnace.
Removed the screws that hold the black squirrel cage fan shroud on, slid the shroud as far as I could to the side. Broke up the stuff, scraped, blew it out, and cleaned some more.
I think I got it all.
Going to put it back together this weekend.
Need the chrome thing and some sealant(s).
Thank you all for your help,
KRS
Air bags
Old 01-14-2011, 07:37 AM   #18
KyDan's Avatar
Great that you found the problem.
Sorry that the outside vent cover got trashed.
You can buy them online from various RV parts places
and your local RV parts counter either has
them or can order. (The photo of a vent that I posted
earlier came from an online parts seller.)
They also sell stainless steel screens that are easy
to attach to your furnace flue and also
the outside vent on your LP water heater.
I have them and so far they have done the job for
me as far as keeping the mud dauber wasps out.
You can use ribbon caulk if you want to.
You can also use "plumbers putty" available at
any hardware store. Don't put on too much.
You don't want it to squish out inside and be a possible
fire hazard at the exhaust opening. I suppose most
any outside caulk could be used under the flu cover
when you're installing the replacement.
Happy Camping!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 01-15-2011, 08:10 PM   #19
KRS
KRS's Avatar
Tested, finished instal, replace exterior dual-vent, sealed that up.... good to go!
Thanks for the help,
KRS
Air bags
Old 01-17-2011, 07:37 AM   #20
KyDan's Avatar
Don't forget your bug screens!!
Furnace Insect Screens to Protect your RV
Peace!
Dan & Rita D
Blue Ox WD hitch
