Old 10-26-2015, 11:19 AM   #1
Dometic thermostat E1, furnace fan runs but no heat
I recently removed the AC from my trailer, reconnected the two wires from the Suburban NT-20SEQ furnace to the Dometic AC3313192 thermostat 12v-, 12v+ wires, leaving the blue "comm" wire unconnected. The furnace fan runs for a while then stops, but no heat. the thermostat displays the temp set point, alternating with the E1 error code. The furnace heats if I connect its two wires together. Any ideas why the thermostat is not communicating with the furnace with this setup? How should the furnace be connected to this thermostat?
prg4533 is offline   Reply With Quote
Old 10-26-2015, 11:53 AM   #2
http://www.bdub.net/manuals/Suburban_Service_Manual.pdf is the service manual
denville is offline   Reply With Quote
Old 10-26-2015, 12:07 PM   #3
http://www.dometic.com/QBankFiles3/E...nual_17590.pdf. Read page 3 you must initialize the system for it to communicate with the controller
dometic, fan, furnace, thermostat
