So, my first on this forum is due to my recent new "relationship" with 2001 GeorgieBoy Pursuit. Not sure I am cut out for it.
The first thing I learned is the manufacturer is long gone, changed hands multiple times, and Forest River explains they got no tech literature to share in the end. "Go to a service center". I understand.
First I was drafted to replace tv antenna that was 'eaten' in upright position while leaving parking cover. Was fairly straight forward.
I just survived the nightmare of replacing driver front BigFoot solenoids. Impossible to access, and more. This included replacing starter battery and both house batteries, along with battery tenders for each. May be fixed!
Now asked to confront
current issue: the interior overhead DC lights do not work when (a) disconnected from shore power (b) generator not running. I am promised this used to work, I assume from house batteries. I have learned what a Battery Disconnect Switch is by the door, and have found the relay under hood. The relay does have good 12v on both sides when control switch is in USE position. But no DC to interior lights. I don't know the flow of DC leaving the battery disconnect relay.
I need advice on next test/repair step - additional relay(s), breaker(s), why lights get no DC. ???
I do know it has a Converter/Charger but no indication of an Inverter, or where to look for one.
Lights do work when shore power connected, or when generator running and plugged in to feed coach. Going back to RV in week or so and hope to be armed with fresh ideas so I can get RV boondock capable.
