Hi, I have not done any modes to my new camper has of yet; but on my 2010 318SAB Cougar I needed to install a satellite feed. I drilled the installation hole for the waterproof connection in the floorboard under the entertainment section. This I figured was the safest location to prevent water entry into the camper. Water will not travel up-hill. I then caulk the connection with waterproof caulking that is used for RV trailers.
I would suggest that you go to a camping store and look for some sort of plastic device would allow you to pass the wires thru from under the camper so as to prevent water enter from a driving rain or water run off.
Jim W.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
