If I'm feeling lazy, I boil water and use coffee "tea" bags or put my favorite ground coffee in a tea strainer.
No electricity used just propane to boil the water.
This is what we do when we're dry. I find I don't particularly like the taste of the bags as much, but I'm camping..I'll get over it. I'd be doing the same thing if I were in a tent.
No, do not like the bags. The pot referenced above is as close as you can get to a non electric Bunn coffee maker as you can get. I like my coffee so it is worth the cost to me.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
Unlike many, I'm not a coffee snob and less so when camping. I love using coffee bags on long ATV or snowmobile trips when I stop to take a lunch break, heat up some food and add a steaming cup of coffee to go with it....warms the soul.
I don't consider myself a coffee snob but like what I like. I have a one burner propane stove I can heat water on. Also have a filter strainer from a dead coffee pot. Been know to put a filter and coffee in it and balance it over a glass carafe. pour water thru it and have hot coffee for lunch. This stays in my truck for when I need it. All spare parts but it works, LOL!
Jim
George Bernard Shaw
Tea strainer. Never thought of that. Will give it a try. Have a French Press but seldom use so that too is an option for travel without hookups.
I am a zombie without my morning coffee. Two cups at least before I can talk.
We have stayed in RV parks that offer morning coffee. A life saver.
GT
2004 Dodge RAM Cummins Diesel New Venture six speed 4x4 crewcab
2016 Rockwood 8280WS
Two 5 year old herding dogs - that shed year round
You might be surprised to learn that your fridge draws over 25A or more a day. This is for a fridge running on propane; caused by the fridge's door seal heater.
Check the control panel for your fridge for a connection labelled "light/heater" If you remove the wire plugged into it, it will eliminate this drain on the battery but will also turn off the interior light. Be careful removing the wire if your fridge is plugged into 110AC because there's usually an exposed 110 connector nearby.
I always unplug the wire on my fridge when dry camping.
Phil
There is a very easy mode to fix this.
If your fridge has a switch in the freezer door make sure it is OFF when on battery.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
