The problem is that NO 12V (or two 6V) lead acid batteries, even when fully charged, put out more than 12.7something volts. So something is not right when you are reading 12.9V+. There is one likely explanation besides mis-calibrated voltmeters - and that is that the battery is being charged, or has recently been charged when you take your voltage reading. If the batteries have been on a charger in the 24 hours prior to a voltage reading, it is possible to read higher than 12.8V. Otherwise, not. Or you batteries are not traditional lead-acid batteries.
Fred W
Fred W
