Old 08-17-2015, 11:01 PM   #1
LaxRef93's Avatar
Dumb generator mistake
In rushing to get ready for our first dry camping trip, I went to Cabelas to get a generator. Picked up a Yamaha. Nice and quiet, and I really liked it. However, I wasn't thinking about what size to get and only picked up the 1000 watt (7.5 amp) for our 30 amp trailer.
It worked okay to charge the battery, charge our phones, and run the pump. But it kept tripping every time we wanted to use the Keurig. (I know.. First world glamping problems).
Yes I should have gotten the 2000 watt. Anyone want to trade?
Sent from my XT1060 using Tapatalk
2014 Tracer Ultra Lite 2670BHS
2014 Ram 1500 Crew Cab 5.7L Hemi
Camping Trips 2014 - 3 trips, 7 nights
Camping Trips 2015 - 2 trips, 4 nights
(7 more trips planned)
LaxRef93 is offline   Reply With Quote
Old 08-17-2015, 11:17 PM   #2
John McClain's Avatar
where you from I have a friend looking for one ?
Or maybe use a large inverter to run you Keurig
F-250 . stealth 3210 solar pannels, fantastic fans. and life line batteries
John McClain is offline   Reply With Quote
Old 08-18-2015, 06:33 AM   #3
TURBS's Avatar
Hope you don't plan on running the a/c with the 2000 either.
2000 running watts or surge watts?
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Old 08-18-2015, 06:38 AM   #4
Herk7769's Avatar
A 2500 watt inverter will handle the Keurig but neither his battery nor the generator (Even together!) will supply enough juice to run a full brew cycle.
HAM CALLSIGN - KC3FFW
Old 08-18-2015, 06:39 AM   #5
KyDan's Avatar
My advice is get a stove top percolator for coffee and keep the lighter genny for charging and put the $avings in your pocket. Lighter weight might save your back too!
It probably won't run your microwave tho.....
How often do you dry camp?? Rarely- you're good to go with my suggestion above.
Often- you probably want a bigger genny.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 08-20-2015, 10:43 PM   #6
Dabmeb's Avatar
We run our kureg on a 1500 watt inverter
Dabmeb is offline   Reply With Quote
Old 08-21-2015, 07:44 AM   #7
Herk7769's Avatar
Originally Posted by Dabmeb View Post
We run our Keurig on a 1500 watt inverter
How big is your battery capacity?
No one is saying you can't; just that the typical single "marine" size 24 battery won't hang in there long enough to make several cups of coffee.
A 1500 Watt inverter will draw 125 amps at rated load.
A typical Keurig will draw 800 watts when heating or 67 amps.
Since most Group 24 Marine batteries have about 70AH of battery life (at 5 AMPS draw), at 67 amps a fully charged battery will reduce a 100% battery to inverter cut out voltage (10.5 volts) in about 15 minutes.
Next time you do this watch your micromonitor display and watch what happens to the "voltage idiot lights" as the coffee brews.
Remember also you must recharge your battery when the "Good" light goes out (50% discharged) in order to prevent permanent battery capacity loss.
Name:	battery voltage and capacity Curve vs Discharge Rate.jpg
ID:	86415   Click image for larger version
Name:	Battery Display.jpg
Old 08-21-2015, 07:55 AM   #8
No one is saying you can't; just that the typical single "marine" size 24 battery won't hang in there long enough to make one cup let alone more.
I'd like to see that inverter. 1500 watts is 12.5 amps at 120 volts.
Brewhedd is offline   Reply With Quote
Old 08-21-2015, 07:56 AM   #9
I believe it will require at least a 3000 watt genset to handle the air cond.
With the old 30 amp Durango we had before, our 3000 watt genset would handle it okay, but if we wanted to make coffee, I had to disable the compressor in the Ac unit until we had our coffee. Then unplug the coffee pot before turning the Ac back on. Same with the microwave or other heavy power use appliances.
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
Davidg is offline   Reply With Quote
Old 08-21-2015, 08:01 AM   #10
Keurig coffee is over rated use a malita with filter, that way you can get the cup of joe you like at 15% the cost, unless you go gourmet, then your only saving 70% per cup. Just sayin'
generator
