Old 05-05-2011, 09:45 PM   #1
Bear's Avatar
Electric drain valves
I am thinking about putting electric drain valves on my 5'er. Looking for input on reliability and pricing, and if possable a source for the in Canada. The reason I need to put electric drain valves on is FR did a horrable job of placement on the stock valves. To drain both grey water tanks I need to crawl right under the trailer. I installed cable operated valves when I bought the trailer, but they keep failing due to the extream angles they need to be mounted at to install. I need three 3" valves and one 1.5" valve.
2000 Volvo 660 D12 425 hp 1550 torque 15 speed, Trailer Saver air ride hitch. 2006 Canadian Sport 385 RLTS 40'10" triple slide, triple axle 5'er toybox, 300 watts solar, 3000 watt inverter, Onan 5500 Marques Platnum. 1998 Polaris 300 Explorer 4X4 quad, 2003 Polaris 700 Sportsman 4X4 quad, 1994 Jeep YJ "TOAD" 3" lift 31" ProComp Mud Terrain tires
http://community.webshots.com/user/Bears319
http://www.picturetrail.com/bears319
Mission Statement : ZZZZzzzzz
Bear is offline   Reply With Quote
