Originally Posted by 6CatDaddy
Hi, wife and I have the 1905 on order, this question I should have asked the dealer, and still can but thought I would ask here...
Is everything electric in the trailer 12 volt, and stepped down when shore powered or on generator, or... ??
I may have answered my own question here, but the fridge runs on propane or 120v, it has a microwave too, are they hard wired 120v or is there an inverter from 12v battery to step up to 120v?
The a/c I assume is hard wired 120v.
Is the led tv that comes with the trailer 12v, or 120v?
When connected to shore power or generator, is there a battery charger built in to keep batt charged?
Getting back into rv'ing, camping after 30+ years of being away from it.
I won't ask if a 3000w inv/generator will power the a/c while using tv, lights etc.
Thanks for any input!!
Doing all the thinking, planning for getting back into rv'ing, get one thing answered and I come up with 10 other things I need to find out about. Haha!
I can go down the list for you...
1) Most is 12V except for outlets, ac, and usually the tv. There is a converter that takes the 120 to 12V when on shore/gen.
2) Fridge is propane or 120. The micro is 120 only. No inverter.
3) AC is 120 only
4) Tv is 99.9 times only 120. They do make 120 and 12V tv's, but not usually standard.
5) Yes, batt will charge on shore or gen
6) 3000W gen may work, may not. I have two Honda 2000's that work. I tried a Champion and it didn't work. Friend has the Firman and it works for him. Never know with generators.
