Old 03-17-2014, 07:31 AM   #11
non functioning outlets.
I am so sorry. I failed to mention the outlet in the bedroom next to the TV cable hook up is also non functioning and on the passenger side of the trailer in the bedroom there is an outlet close to the floor with no reset button that is fully functional.
budster is offline   Reply With Quote
Old 03-17-2014, 07:50 AM   #12
iowaborn's Avatar
Send a message via AIM to iowaborn
Originally Posted by OldCoot View Post
I would start by pulling all the receptacles and check for loose wires, especially the GFI outlets. The wires from this receptacle to the other outlets could be loose and the reset won't make any difference.
X2
I hate the practice electricians use of "stabbing" the bare wires into outlets. I know it is because of labor costs, but every failed outlet I have fixed is because of a high resistance connection on a stabbed wire of daisy chained outlets.
Iowa: Not as bad as you picture it.
2013 F-250 CrewCab 6.7 PowerStroke 4X4
2017 Silverback 33RK
iowaborn is offline   Reply With Quote
Old 03-17-2014, 08:13 AM   #13
fonzie's Avatar
Originally Posted by budster View Post
The outlet in the TV cabinet is the same as the other two non functioning outlets. No reset switch.
I do have a question. Is it possible that the three non functioning outlets are on a series not involving any other outlets or lights ? When the portable heater was plugged in and then the hairdryer was turned on it literally fried that receptacle and the only thing needing to be replaced is a new receptacle ?
If you can't tell I hate working with electricity.
Yes very possible......
Fonzie
Old 03-17-2014, 08:18 AM   #14
wmtire's Avatar
I concur with Fonzie. Now that we know that the receptacle was indeed fried, yes, it is very possible (and highly likely) that the non-functioning outlets are all downstream of the burnt outlet on the same circuit.....thus not functioning.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 03-17-2014, 08:26 AM   #15
Somewhat right of center
Crabbyguy's Avatar
I'd go with that too. Space heater and hair dryer in same outlet....not a good idea.
2014 Crusader 260RLD Champagne Touring Edition
2013 Silverado 2500 6.0 HD
Crabbyguy is offline   Reply With Quote
Old 03-17-2014, 08:42 AM   #16
Same here too.
2012 Rockwood 8314BSS
2011 Chevy
Camping, Dutch Oven Cooking, and Homebrewing
campdohbrew is offline   Reply With Quote
Old 03-17-2014, 10:21 AM   #17
fonzie's Avatar
Disconnect shore power, replace burnt receptacle, wire correctly, hookup shore power and test receptacles....let us know.
Fonzie
electric
