Old 06-04-2017, 08:23 AM   #1
2016greywolf's Avatar
Electric Question
I have a Grey Wolf 29BH. I am not getting power to anything with battery power. I have changed out my converter and circuit card. Other than that everything works when I am plugged in. Any ideas would greatly helpful.
2016greywolf is offline   Reply With Quote
Old 06-04-2017, 08:28 AM   #2
A32Deuce's Avatar
All of your fuses ok? Does not take much to blow a main fuse.
A32Deuce is offline   Reply With Quote
Old 06-04-2017, 08:35 AM   #3
All the fuses are good.
Old 06-04-2017, 08:36 AM   #4
Is there any other fuses or circuits between the battery and the main fuse box?
Old 06-04-2017, 08:38 AM   #5
Battery disconnect?
2019.5 Rockwood 2509S
Toddupton is offline   Reply With Quote
Old 06-04-2017, 08:49 AM   #6
wmtire's Avatar
Yes, you most likely have a resettable 12 volt DC circuit breaker on your frame rail. This has a small button on it, you press to reset. We have many many threads on this, Here is just a recent one.
http://www.forestriverforums.com/for...ml#post1518638
Another things that can cause your symptom, is if there is a battery disconnect somewhere, and it's turned off...which disconnects the battery from the parasitic electrical draws. We have members who don't realize this also cuts off the 12 volt DC power to most everything. Some RV's have a factory installed battery disconnect switch. It's possible yours does.
I would venture to say your problem is caused from the resettable circuit breaker being tripped (find it and press the small button if equipped)...or you have a battery disconnect turned off (if equipped)
2011 Flagstaff 831 RLBSS
Old 06-04-2017, 09:08 AM   #7
by change did you just get it from the dealer? has it worked on battery before? this is a stupid thought but is the battery installed and connected? if so, probably that resettable circuit breaker.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 06-04-2017, 09:37 AM   #8
Everything is hooked up correctly. I will look for the resettable circuit breaker. Thanks everyone.
Old 06-04-2017, 10:03 AM   #9
onetonford's Avatar
Are you talking about a Converter or Inverter? because a converter is for making 110v ac to dc and a inverter is for 12v dc to 110?
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 06-04-2017, 10:10 AM   #10
Thanks for the assistance. That did the trick.
Old 06-04-2017, 10:11 AM   #11
Thanks for the input everyone. wmtire had the solution I needed
Old 06-04-2017, 10:13 AM   #12
wmtire's Avatar
You are welcome and great to hear that got you fixed up. Welcome to the forums and thanks for your service to our country.
electric
