Old 07-16-2015, 09:51 PM   #1
Electrical 50amp cord from rv
Can an electrical cord still be safe if the ground plug has been pulled out by the surf protector? 50amp
PFurlow is offline   Reply With Quote
Old 07-16-2015, 10:19 PM   #2
TURBS's Avatar
Negative.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "11 nights"
Old 07-16-2015, 10:23 PM   #3
davel1971's Avatar
absolutely NOT
David & Lynn
Old 07-16-2015, 10:33 PM   #4
We placed the metal piece back into the plug and plugged into an extension cord (50amp) and plugged that into the receptical at our house!
Old 07-16-2015, 10:33 PM   #5
Why not??? We all used power for decades without the ground terminal.
I'm assuming that you would be facing a situation here where there was no immediate alternative to affect a ground terminal repair. I'm also assuming that you would want to repair the ground terminal just as soon as possible --- but, in a pinch, what would happen if you did use the cord??
bruceatlam is offline   Reply With Quote
Old 07-16-2015, 10:38 PM   #6
davel1971's Avatar
you can buy replacement ends if you don't want to get a whole cord
David & Lynn
Old 07-16-2015, 10:40 PM   #7
davel1971's Avatar
your house is grounded to earth with a long rod into the ground. Your RV is not, it's sitting on rubber tires
David & Lynn
electric, electrical
