Old 11-30-2013, 04:13 PM   #1
Electrical
Can I switch the batteries off while plugged into 110 and live in the camper without damaging anything?
grandmadonald is offline   Reply With Quote
Old 11-30-2013, 04:17 PM   #2
If you have a WFCO converter, no. They don't like not having a battery. A Progressive Dynamics converter would be ok with it. But why do you want to do that?
Old 11-30-2013, 04:18 PM   #3
bikendan's Avatar
my first question is, why would you want to?
don't know what kind of RV you have but some 12v things on your RV may not work without a battery.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 12-01-2013, 06:21 AM   #4
Herk7769's Avatar
Without the battery, all 12 volt items should "work," however you run the risk of damaging the converter if you try running a high demand item.
The camper's electrical system is designed to work off the battery and converter to just keep it charged.
It would be like driving your car without a battery and using a battery charger to start your car.
Bad for the alternator.
HAM CALLSIGN - KC3FFW
Old 12-01-2013, 07:29 AM   #5
Electrical
When I run camper furnace, the power declines, the lights dim, then suddenly the power returns normal, and the cycle continues.
If I turn battery switch off everything runs smooth. WHY??
Old 12-01-2013, 08:18 AM   #6
Great Horned Owl's Avatar
You very likely have a bad battery. If you are lucky, it may just be a case of low water level in the battery.
Joel
2011 Silverado 2500HD Duramax, 4x4, crew cab, long bed
Palomino Puma 253-FBS, 27' 5th wheel
1994 19' Class B on Chevy chassis
Great Horned Owl is offline   Reply With Quote
Old 12-01-2013, 08:38 AM   #7
Herk7769's Avatar
Joel
I would start here. This definitely sounds like a bad cell in your battery.
Old 12-01-2013, 09:25 AM   #8
Lucky is a relative term when used in a battery sense. When the water is low, meaning low enough to expose the lead plates, that portion of the plate that is exposed is now dead, and not able to hold a charge.
2012WhiteSolera is offline   Reply With Quote
Old 12-01-2013, 03:44 PM   #9
bikendan's Avatar
yep, you should be checking the battery from the get go.
sounds like your battery is bad or not being maintained.
electric, electrical
